[ROM][CM9][ICS][4.0.4] Cyanogenmod 9, Android ICS 4.0.4
Hi
i installed cynogenmod9 28th-june-2012 version on my phone lg nitro and now all i get is cyanogenmod9 screensaver. As well, the device starts itself immediately i shut it down.
Somebody help.
I am on Lg Thrive and I've got no boot bug. Are you referring to the one that would show white battery if the phone was rebooted or turned off?
Follow my tutorial a few posts back
Do you have Google Talk or Skype?
I'll be able to help you a lot more that way :)
i have phoenix and on oldbb tried p505 build 2012/07/02 rom works but when flash oldbb patch after LG logo i get blackscreen!!
Yes. Only shut off and on. Not reboot.
Sent from my LG-p505 using Android Central Forums
Has anybody been able to change the LCD density on CM9 ROMs? I can't seem to get it to work
I have somewhat of a noob questions. I decided to try the whole link2sd thing. When I format my SD card I only have the option to choose the SD_Ext size and the Swap size. There is no EXT_2 and I don't know how to format EXT_2 to Ext_3. Does anyone have some more directions for this link2sd stuff?
Never mind, it all seems to be working fine this time.
Eastern Standard (GMT -5)
I have time now, but we're having issues with our router. Going to go return the piece of crap and get a new one.
Same here but i would like to do it later tonight because i have company over if thats ok with you
sukarisw17
