[ROM][CM9][ICS][4.0.4] Cyanogenmod 9, Android ICS 4.0.4
I have somewhat of a noob questions. I decided to try the whole link2sd thing. When I format my SD card I only have the option to choose the SD_Ext size and the Swap size. There is no EXT_2 and I don't know how to format EXT_2 to Ext_3. Does anyone have some more directions for this link2sd stuff?
Never mind, it all seems to be working fine this time.
Hello!!! :)
I'm an expert on Link2SD!!! :mad:
You need to create two (2) partitions, both must be primary, first partition FAT32, second partition FAT32 (Stock ROM) or ext4 (Custom ROM)... I always use this tool: MiniTool Partition Wizard Home Edition!!! :p
Same here but i would like to do it later tonight because i have company over if thats ok with you
Hey sorry about that. Our router screwed up and I couldn't access half the internet....
Something to do with IPv6 but I gave it a piece of my mind :P
I'm available today if you want to do it :)
Arjen, just wondering, will the P505 ROM perform as expected on the Thrive or will it be like the ones from before? They just black screened and you had to re-flash the ones from the P500
Thanks!
Rashed can we please do this today before 7pm. I am going away and i wont return until saturday night so please add me on skype or get back to me.
Do you want me to help you already? What is it that you need to do? We can talk on Google chat now.
Sent from my LG-P500 using Tapatalk 2
My sd is not working on my phone but it works inside other phones and my pc, it doesnt even detects when i put it in, could it be the slot or the pins,??im using 07022012 p505 rom
Sent from my LG-p505 using Android Central Forums
Thanks!
They should perform the same.
Can you try to get a logcat from it?
I know there are different versions of the Thrive.
Try to flash the latest weekly, it should be up by now.
check if the sd card is recognized in cwm and flash a different rom and see if it works then, if its not recognized in cwm try another sd card, if it still doesnt work its probs the pins
Did it never work on that version?
Is it possible to change the messaging app's theme to black?
Sent from my LG-P506 using Android Central Forums
Nazeer zaheen
