[ROM][CM9][ICS][4.0.4] Cyanogenmod 9, Android ICS 4.0.4
Thanks. I also looked it up today but at first I was like who is this Rogers I keep hearing about?
Sent from my LG-p506 using Android Central Forums
Arjen, I have a working HeHappy P505 TinyStream rom with no boot bug, nor errors at all (small ones mentioned in his xda thread). Would you want to look at it for a bootbug fix? :D
If yes, It's here: http://www.mediafire.com/?54kpgfnpm6lnqv5 (unsigned so turn the verification thing off:p)
He's working on it, still patching, but getting close.
Sent from my LG-p505 using Tapatalk 2
Ah OK. Yeah I've been trying several roms since my incident a week ago but arjens cm9 build is the best. I know he won't disappoint with this jb build :D
I'm very excited to see his jb build as well ;)
Hello!!! :)
?Can you give me some detail information about what ROMs, Kernels that you used on your phone?
Thanx a lot!!! ;)
If yes, It's here: cm9.0.0-rc1-tinystream-Hehappy_PortedbyBownz-p505.zip (unsigned so turn the verification thing off:p)
Thanks, I was fed up with booting into recovery mode each time I turned on my phone.
Reactions: PacketBoy
You still have this issue?
Hephappy his rom is build from the same sources...
Sent from my iPad using Tapatalk HD
I have the issue, as do several others. The main thing I did with this version's is I kept HepHappy's boot.img-ramdisk and replaced the zImage with yours from the 20120714 build.
Hello!!! :)
Thanx a lot!!! ;)
Basically I tried the aosp and aokp roms but I like Arjens better (less buggy) and I also tried cm7 which I am going to flash again tonight because I want to watch YouTube videos without having random reboots. I am going to return to a backup of Arjens rom after I am finished watching BC his rom is awesome. As of kernels, I only use arjens kernel bc the other roms already had kernels built in. (Don't forget to flash bb fix!)
Hopefully arjen can fix the blackscreen bug from the GB kernel so we can all try some GB roms.(There are quite a few 100% stable GB roms out there, but are unuseable because of the blackscreen bug.) It probably needs the same fix arjen used on the ICS kernel.
He's focusing only on JB and his ics rom, piccolo atm.
gaganprasad
