[ROM][CM9][ICS][4.0.4] Cyanogenmod 9, Android ICS 4.0.4
So does my ROM work now?
Hope this isn't a double post. If this is directed to me, I dunno yet. Haven't redownloaded it yet. As soon as I can I will test it again. Prolly tomorrow after work.
Sent from my LG-P506 using Android Central Forums
Mates, are you using link2sd ir something?, i can't when i move apps to sd after 15min it's start to say me sd is damaged or randomly mounting ounmounting.
Sorry for my english
Thanks arjen for all work and all of you too
sent from my lg p505
Using an ext partition is a prerequisite if I'm not mistaken. From what I've read that is common between all of the cm9 ics builds. I have an ext-4 partition and do use link2sd . I think they recommend an ext-3 partition tho.
I did a partition with CWM, Bit still have that problem, how do i do aun ext-3 ir 4?
1) Backup sdcard ( just in case )
2) Boot device into CWM Recovery
3) Select advanced menu
4) Select Partition SD Card item
5) Follow the prompts from there
6) Reboot device
7) Install Link2Sd from Play Store
That should get you rolling. ;)
Is it a known issue or just me, but siri clone apps and even trying to use speech to text for SMS doesn't work. Speaker phone mic works fine during calls but trying to text or navigate with speech doesn't respond at all. Didn't have the problem on cm7 but have always had the problem with cm9.
If you have problems with link to sd, the easier way is to use terminal emulator and change the default install location to external. Then you will be able to move your apps.
Sent from my LG-p505 using Tapatalk 2
What voice search are you on? Here's how to fix it.
1. Use a root explorer and get into system/app, find the voice search apk.
2. Rename it to Voice.apk1 or similar.
3. Reboot
4. Go into the play store and install voice search from there an voila! Working voice commands.
3. Reboot
Great man worked perfect. Thanks!
Update on jelly bean, I've began building haha, so hephappy uploaded a crucial error fix, and also uploaded color banding fixes! ;) so I'm patching it up now and will build again, hopefully with no errors. And if anyone grumbles that I'm taking the spotlight away from arjen, he ASKED me to begin building, so please don't.
pratikkumarBB
