[ROM][CM9][ICS][4.0.4] Cyanogenmod 9, Android ICS 4.0.4
Basically I tried the aosp and aokp roms but I like Arjens better (less buggy) and I also tried cm7 which I am going to flash again tonight because I want to watch YouTube videos without having random reboots. I am going to return to a backup of Arjens rom after I am finished watching BC his rom is awesome. As of kernels, I only use arjens kernel bc the other roms already had kernels built in. (Don't forget to flash bb fix!)
Sent from my LG-p506 using Android Central Forums
Thank you so much!!! :)
BTW: ?Where is the BaseBand FIX? :p
Ill upload the Baseband fix for you when I get to my PC.
What do you mean?
I've got the April 29 2011 ICS Apps
That's the most updated version
Sent from my LG-P506 using Android Central Forums
Great News!
I have an updated Thrive ROM!
Built off of the 7/14 P505
I have fixed the boot issue so you can now boot normally again
It also includes the old BB fix and GApps so you don't have to flash anything but the ROM
Also, it fixes issues with sound and random rebooting (I think it fixes them)
Have I missed anything?
Download link: Link with held until next update today
Reactions: AdictoDigital
Great News!
Download link: http://dl.dropbox.com/u/56064156/7-14-12_ICS.zip
Way to steal Arjen's thunder... It's Arjens thread, I posted the Hephappy-nobootbug-rom post earlier just so Arjen could figure out exactly what Was causing this. Thanks and all, but I would of just held off until Arjen got to it.
Great News!
Well done mate!
Nice to see some more are getting active on improving things ;)
Reactions: Rashed1997
Thanks!
I discovered a bug in it
I hope nobody liked the charging animation...
If your phone is off and you connect to your charger it will just boot up.
But at least we can boot now :p
I really dont know what the fuss is all about with this boot bug. If you guys are referring to the black and white battery icon, just hold power and the phone turns on.If it boots with the battery logo again,hold power one more time and it WILL work 100%.
I can confirm this too. I usually just hold the power button til the phone shuts down and then reboots.
I tried that. It just keeps going to the battery animation
If you have to turn phone on using some trick then this is merely a workaround and is not good practice. Yes workarounds can work but ideally we need to have this issue fixed so that CM9/10 is a good complete solution for anyone out there willing to modify there phone.
Long pressing the power button (holding the power button down) until it boots works fine for me.
I've found another bug in my Thrive build:
Random rebooting not fixed
Guess I've got a bit more stuff to do :P
Mohamadharika500
