[ROM][CM9][ICS][4.0.4] Cyanogenmod 9, Android ICS 4.0.4
will this work for the pheonix as well if not will you please build one that will
It is made for the phoenix, Thrive users must flash an "old bb fix" for Wireless communications. Wifi is not working. There is color banding (but not too bad.) Gapps do not work. Nor does the camera. And at boot it gives the error that the phone has crashed. however the phone still works.
Um.... Never mind, I'm good without it.
I don't have data so that wouldn't be useful at all
I know, ditto. It's just fun to play around with for a little :p Hopefully Arjen or Hephappy will release a far more stable version soon, because mines far from perfect.
Haha, yeah.
Making changes to my Thrive build, hopefully will fix some stuff
Bownz, do you have a Google Talk or Skype?
I could really use some help....
Hello from my Mac VM :D
Re-downloading the original JB code from Google then I'm gonna try to get the source you uploaded on Github Arjen
Hope Eclipse doesn't complain again this time.....
Reactions: AdictoDigital
You guys who are helping build the jb rom are awesome!!! :D
Can we expect a stable rom in the near future? (like 1 to 2 weeks)
Sent from my LG-P500 using Android Central Forums
Well, Arjen wants me to try compiling to so I'm trying to install ubuntu now.
Sent from my LG-p505 using Tapatalk 2
I apparently cannot install this rom either. Installation aborts with Status 7, same as piccolo. Again I have an LG Thrive P506. Have no problems with the P500 build of this rom.
What CWM do you have?
If you're using the one officially for the Thrive and Pheonix, it has this issue.
You have one of 2 choices:
1. Use the normal P500 CWM from Rom Manager and then flash that ROM
2. Wait for Dropbox to be back up (it's down ATM) and I'll release a better build tonight with support for the CWM Arjen made
If you're not using that CWM then its something else
CWM 5.0.2.7 Touch for P500. I actually just found a version of the above mentioned that was built for P505/P506. And I did try installing this rom and piccolo after flashing this recovery and then restarting the recovery.
Sent from my LG-P506 using Android Central Forums
Hello!!! :)
?Can you share that CWM version with us? :p
Thanx a lot!!! ;)
Qbaumildand
