[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [ROM]COLD AS ICE-CM9 Sprint LS670 9/1 ZVD basesband Alpha17
For the provisioning, you need to be on a sprint based rom. Easiest way is to back up in recovery and flash Reborn rom for zvd or if you are on baseband zvj one of the zvj sprint based roms. Then update provisioning and prl. Then restore your backup.
I"m not sure on the silence on the lockscreen option. Maybe make a profile that does it.
Thanks, Kraven. OK, that's good to know. I'll download Reborn to be ready for that.
OK, a profile. Well, that probably makes more sense. If I find that action again I'll post it here. It was really cool, in one touch I could silence the phone for X Min or X Hr. Really nice.
Thanks again for an excellent ROM. I was running your CM7.2 and got enticed with folks saying how nice this one is. I concur!
I know I mentioned it earlier, and that it's been an error before, but I have to think this is costing performance/battery. Logcat is attached.
Code:
I/Adreno  (  536): ioctl code 0x40140931 (IOCTL_KGSL_TIMESTAMP_EVENT) failed: errno 22 Invalid argument
D/dalvikvm(  610): GC_CONCURRENT freed 930K, 33% free 8490K/12487K, paused 5ms+24ms
D/HardwareRenderer( 2681): Disabling v-sync
D/libEGL  ( 2681): loaded /system/lib/egl/libEGL_adreno200.so
D/libEGL  ( 2681): loaded /system/lib/egl/libGLESv1_CM_adreno200.so
D/libEGL  ( 2681): loaded /system/lib/egl/libGLESv2_adreno200.so
D/HardwareRenderer( 2681): EGL configuration com.google.android.gles_jni.EGLConfigImpl@40eb9258:
D/HardwareRenderer( 2681):   RED_SIZE = 8
D/HardwareRenderer( 2681):   GREEN_SIZE = 8
D/HardwareRenderer( 2681):   BLUE_SIZE = 8
D/HardwareRenderer( 2681):   ALPHA_SIZE = 8
D/HardwareRenderer( 2681):   DEPTH_SIZE = 0
D/HardwareRenderer( 2681):   STENCIL_SIZE = 0
D/HardwareRenderer( 2681):   SURFACE_TYPE = 0x5e5
D/OpenGLRenderer( 2681): Enabling debug mode 0
W/Adreno200-EGLSUB( 2681): SetSwapInterval() interval: 0 not set
W/InputManagerService(  610): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@40f437f8 (uid=10061 pid=803)
D/dalvikvm(  777): GC_EXPLICIT freed 3148K, 59% free 3381K/8131K, paused 7ms+28ms
I/ActivityManager(  610): Displayed org.jtb.alogcat/.LogActivity: +1s446ms
W/NetworkManagementSocketTagger(  610): setKernelCountSet(10061, 0) failed with errno -13
Was there a solution?
Any ideas how to force 1xrtt data?
Sent from my Nexus S 4G using Tapatalk 2
You can flash back to stock and use the dialer code to reach programming menus to disable 3G, or use 3rd party tools on your PC like DFS or CDMA workshop.
Now for my question, I'm running 17F Alpha and for some reason M2SD and S2E aren't working. At least, they don't move apps. S2E constantly says "A Reboot is Required" when I go to it, and M2SD doesn't move anything. Did anyone else do anything special to get these running? Yes, I have a properly formatted ext partition.
SMS is messed up
Sent from my LG-LS670 using Android Central Forums
Reborn worked perfectly. Thanks!
How do I get rid of the SMS messages showing up when someone leaves me a VM? Am I doing something wrong?
Thanks! Got my flashed phone data working on a verizon mvno.
I used dfs tool and set it to use is2000.
This is more functional than ur cm7 now... NICCEEE!!!!!!
Sent from my LS670 using Android Central Forums
amazing battery life!
still white screens on gmail.
How do I get rid of the SMS messages showing up when someone leaves me a VM? Anyone?
One solution is google voice. There is a fix in the works on the cyanogen code review. It's a universal issue for all sprint phones using vvm
Re: [ROM]COLD AS ICE-CM9 Sprint LS670 10/6 ZVD basesband Alpha17
New mini update build. 10-6-2012
Alpha 17GSprint vvm 9016 fixes, new audio routing...test for notifications playing in the headphones... Added home button answers call option. Fastcharge kernel , need to flash the fastcharge settings also in post 2
The Virgin patch probably won't work with this build yet. All that wouldn't work is the home answer call feature if you used the virgin patch
Alpha 17GSprint vvm 9016 fixes, new audio routing...test for notifications playing in the headphones... Added home button answers call option. Fastcharge kernel and fastcharge toggleswitch options
I flashed it but I don't see the toggle switches in the settings. I do see the home awnsers call. Also in the about screen it looks like it wasn't updated.
Wow, that was fast. Do you recommend trying a dirty flash with these mini update builds?
I chose the wrong word, it's just a system setting that you check on or off for the usb fast charge. And i did forget to include it. Just flash this http://forums.androidcentral.com/at...and-alpha17-fastcharge.cm9alpha17f-signed.zip
I always wipe cache/dalvik and system, then flash the rom + gapps + the fast charge addon above. You could just do a wipe cache then do the flashes.
This is just a last update till alpha 18. So it will be the same alpha17 base in the about screen. I'll try to get the camera working better on the panoramic.
First off I love this rom so far. I look forward to the later versions being released ASAP. For now I have a question though. I noticed my batter power drains really quickly. And when I go to check what is using my battery it says it is my display.My brightness is all the way down, and it's a 30 second timer. As an example at this moment it says 2% of my battery used by Android OS (the lowest usage), textplus using only 5% of the battery (second highest usage), and the highest usage at 87% being the screen. Anything I can do to fix this?
Omg!!! TheKraven is awesome!!!!! Audio routing was a success!!!!!! I can listen to music and get text now! Thank you! :thumbup::):D
wokulbo1
