[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [ROM]COLD AS ICE-CM9 Sprint LS670 10/6 ZVD basesband Alpha17
Kraven, I noticed the other day that I can pull down the my top bar while at my lock screen. Is it supposed to or is there a setting I dont see.
That's only without a password on. Its so you can check your notifications without unlocking. ;)
@Kraven, I was wondering if I can use tour from as a base? :confused:
I love the sound of this!! :D
I keep getting package file is invalid from the play store after attempting to install an app is the only fix for this problem re-flashing the rom I tried the delete cache/data from play store that didn't work
With that usage and non stop music playing, not bad ;D
USB Fast charge is fantastic! 40+% in just 5-10 minutes!
And a Offline charging bug is there. Can anyone confirm this?
So, there IS a VM fix for Alpha 17G?
Same one as the earlier Alpha 17
There's a new 17G virgin fix.
Will be giving this a shot tomorrow! I want to check that fast charging::D
Don't forget to flash the Fast Charge patch. It'll give you the setting call led Advanced. :)
And idea why it keeps saying Android is upgrading Optimizing application 1 of 1 when i reboot it?
I always wipe cache/dalvik and system, then flash the rom + gapps + the fast charge addon above. You could just do a wipe cache then do the flashes.
No love on the Sprint VM text from 9016. I get 2-3 per VM. Followed directions of wiping Cache/Dalvik, System then flash ROM+GAPPS+Fast Charge. Also tried to shortcut, no difference.
Thanks for your hard work, Kraven!
First things first. Great Work! This is my first time rooting and flashing a phone. I love this ROM. I haven't added the fast charge part yet. But I am enjoying seemingly better battery life from just one days worth of playing around.
I have run into two bugs though, I think one was mentioned briefly. The most serious is in the gmail app (which I added from the store). It started having the message text appear when a message was opened then the text would disappear about 1 second later. You could reopen any message and this would happen. A reboot fixed for now. If it happens again I will try killing the process and restarting and report my results.
The second was with notification sounds and apollo. At first when notification sounds played, the volume would dip and you could hear the notification. Now the volume dips, but I do not here the notification sound. Going to play with it later and see what happens. I had earbuds in, so I wonder if it is possible the notification sound routed through the phone speaker and not the headphone jack. I did have the EQ running, and when I was playing and turned that on may be about when the notifications sounds stopped. I know now that I got an email notification thru the speaker, as the phone is across the room charging.
Again thank, and if I can help more in my bug reports, let me know!
I see where it didn't work in the code. Try each one and tell which one hides the 9016 texts.
The second one worked! VVMfix2.cm9alpha17g.zip suppresses all 9016 messages.
Has anyone tried the VVM app install that mentioned here: AOKP Epic 4G: CM9/AOKP Fixed Sprint Visual Voicemail ? There's a comment at the bottom that it doesn't work with the Optimus S.
Google Voicemail...I need both my numbers, my GV number and my Sprint number. They don't have that option. Dangit!
What about getting back the old notification that I have a voicemail, you know, before the VVM days? Is that even possible?
Very nice work, Kraven! Thanks!
This is freaking amazing. I can't believe how responsive and slick this is on this old phone. Very, very nicely done.
My ONLY issue is with video playback. I made some Optimus S optimized videos using hand brake and they don't really play very well. Slow and crummy. I tried the MX Player recommended in this thread and no luck. Still crummy. Any further developments on the video playback front?
I can't flash the rom in cot. I'm on the optimus v. It gave me an assert error
Starting to get those soft reboots and lockups a lot again... :(
I tried using Link2SD,
But when I partition my SD Card it won't mount. Yet- as a single partition- it mounts fine.
So, is it supported or not?
mattellis99
