[ROM][GINGERBREAD] CyanogenMOD 7 Nightly Builds.
MMS had a few bad builds - the newest works OK - try that.
For your BT - Reset your Samsung device to factory default (check the manual for how), delete any pairings you have on the phone then reconnect.
Should work. This is what I had to do to get my BlueAnt working again.
I'm flashing the newest ROM to try to fix the MMS. I have looked everywhere on Samsung's site and no manual for the WEP475. I checked at home but no luck either. I'll keep trying as it only has one button, the volume, and the power so it can't be that hard to reset. Tired of not having it haha Appreciate the help!
@wkupike2000
Here's a link to the manual - but you have to join the site to download - I suggest using a throwaway email address ;)
Samsung WEP475 - Bluetooth Headset Manuals
Great find on this, I sincerely appreciate it! Unfortunately Samsung stinks and doesn't tell how to factory reset it. It says to enter 0000 as the PIN when prompted on my Incredible but I don't get a prompt that allows input. I get a prompt that says "make sure this PIN ##### is showing on the device" Well I don't know about anyone else, but my little headset doesn't have a display or way to enter a PIN.
I don't understand what has happened to cause this issue. When I first got it, my Incredible recognized it, didn't prompt for a PIN, and worked perfectly. Then somewhere along the nightlies it stopped and has never worked again. It says the headset supports Simple Pairing that doesn't require a PIN but that seems to no longer be the case. So frustrated.
I've been noticing something a little bit strange with the last couple nightlies. Instead of the "Verizon" button on the Market homepage it has a "My apps" button instead. Not that I'm complaining, but it just seems kind of strange. Then when I tried to install My Verizon from the web based market I got a message telling me that "this item is not available on your carrier", which makes absolutely no sense whatsoever. I'm still seeing "Verizon Wireless" on the lockscreen and in the notification bar, but the Market somehow isn't tied to Verizon anymore. Very strange.
Any chance they will be able to incorporate the GB camera drivers into CM7 so we can get properly working cameras, or is that just wishful thinking? I love CM7 except for the cameras. I love Skyraider 4.0 except for the battery life. :/
Now that we finally have a gingersense leak Team Cyanogenmod can hopefully get they're hands on the drivers they need for 720p video, and maybe they can do some other improvements as well, like giving us full 8MP still photos (if there is a way to get the current camera to take 8MP photos I can't find it).
I don't think they will be able to much with the leak, they will most likely need the source code for a GB update. I could be wrong though, they might be able to rip the drivers from a leak.
The AOSP camera definitely takes 8MP photos by default, just not in the widescreen format like the HTC camera does.
Are you getting 720p video? What about touch-to-focus? I can't take decent pictures without touch-to-focus.
The stock canera takes 8MP photos? I wonder why Vignette and the MIUI camera look so much better. Like I said, the CM7 camera needs a lot if work.
Sent from my HTC Droid Nexus with Tapatalk.
The Android market from my dinc did show "my apps" instead of "my verizon",, on dx still shows as "my verizon"
However I got curious so I went to the android market from my computer. I saw the verizon home app I have linked below
https://market.android.com/details?id=com.verizon.myverizon.activity&feature=search_result
Im not sure if that's the verizon app you meant for sure but it installed as seen in the thumbnail pic below, 2nd row ,3rd one over from left to right in that row.
PS : My bad thats for something else I think now NOT the same thing as I thought it was at first,:-[
Does anyone know of a fix for the lock screen toggle? On my phone, with CM7 (can't remember which version I'm up to, I've reflashed so many times) the lock screen toggle in the power widget has never worked properly. It disables the lockscreen perfectly, but when I go to turn it back on, I have to reboot the phone for it to take effect. It's super annoying, because this would be such a useful feature to have!
Nightly 89 is up.
EDIT-I got one Android system process force close the first time I booted up Nightly 89 and a network error the first time I tried to open the market, but other then that it's all good. And there might have been some improvements made to the camera as well. I'm going to take a few pictures and see.
Ti Emoti
