[ROM][GINGERBREAD] CyanogenMOD 7 Nightly Builds.
I went from 7.0.3 stable to nightly 99, and now my wifi cycles every 30-45 seconds. I did turn off the "sleep" thing in advanced. Hoping I don't have to go back to 7.0.3...
I'm on nightly 99. I have wifi on 100% of the time and haven't had any problems. You might want to give Incredikernel a try, I've heard it's solved other people's wifi issues on the nightlies.
Sent from my HTC Droid Nexus with Tapatalk.
Reactions: zero neck
Try wiping Dalvik and Cache and re-loading 99 and see if that fixes it. I've been running the Stock Kernel for ages and have had no Wi-Fi issues.
Yes, Incredikernel beta 8 solved the wifi issue. Posted it on cyanogen's forum too so they're aware that there is something wifi-wonky with their embedded kernel. Thanks again for the timely replies everyone :)
p.s. I did do the cache/darvik wipe and reinstalled nightly 99 first and the wifi issue was still there, then installed incredikernel and rebooted and it fixed it.
Reactions: PvilleComp
Happy to help. Glad your issue got solved. :cool:
Finally got around to flashing 100 tonight and it appears that the Wi-Fi cycling is still there. :(
That's odd. I'm on Wifi 100% of the time and I've never had any problems. The last version of CM7 that gave me Wifi trouble was RC1.
100 lets go.
I will have to flash this tomorrow (been slackin lately).
Some say, Stig's motorcycle helmet shows him glimpses of the future with Ice Cream Sandwich... other say, his github is actually a facebook for Artifically enhanced Tamagachi devices that have evolved into deadly robots... All we know is, he's called the stig!
im so lame
Yeah - I've not had any problems with it lately either - could be my AP needs a reboot. I'll play with it today.
100 lets go.
im so lame
LOL
I just started flashing the nightlies and I have a question: if I were to replace the stock camera app with miui, when I flash a new nightly, won't it simply over write miui and restore the stock camera application?
If that is the case, does anyone have a version that installs alongside the stock camera app, or could you tell me how I should set this up so I don't have to continuously flash the miui camera along with every nightly.
*I have been using version 10. I will use version 17 if it has proven stable for you.
Thanks in advance.
Thanks in advance.
This is the .apk for MIUI camera # 17. Install via Root Explorer or Astro. Because it's a .apk and not a .zip file you only have to install it once, flashing a new nightly won't effect it. If the camera freezes or reboots your phone just turn off auto flash.
Your choice
I can confirm what Dark Wizard Matoya says. I am and have been using MIUI #17 for several builds now and haven't had to reinstall it due to flashing new nightlies. I did run into a problem where I opened the old camera app and it seemed to break the link to the new one when I tried to open it. All I would get when I clicked either icon was the stock camera app. I resolved this by uninstalling and then reinstalling the MIUI app. Go ahead and install it if you haven't already. You've got nothing to lose and so much to gain.
Nzone888
