[ROM][GINGERBREAD] CyanogenMOD 7 Nightly Builds.
Your killing it Stig!! Your like the prop comic genius "CarrotTop" of Android Central!! Minus the huge red fro (just a guess) and the roids...(again just a guess)...and the coke (i hope).:D
Sadly, the hair turns grey (and yes the carpet and drapes do match :( ) the only "roids" I work with need Preparation H, and my Coke is Diet.
I used to be the people my mother warned me about... What happened!?
Reactions: zero neck
WOW, you have made me both laugh and vomit a little bit in my own mouth...so thats what we've all got to look forward to? Great.
On a different note, I'm experiencing quite a bit of lag in my CM7. Like from the home screen when I swipe to go the the screens to either left or right, it will take up to a second after I've swiped. I'm not using a live wallpaper or anything special. It's been ongoing for a while now and I actually went back to Skyraider 4.0 because it was a lot smoother but I miss having Gbread and some other features.
Would a repair permissions help? I wipe the data partition and davlic before every nightly flash and I'm currently booting up to see whats up with #102.
Any thoughts?
When was your last clean install?
I've read where that fixes lag.
Reactions: Wanda
You mean a factory reset type. Ugg. Took me forever to get my settings as it is. Does adw's setting saver really work?
Yeah what usually happens with my adw desktop config works when you restore for the most part, but a bunch of the apps won't really come back correctly, so you'll have to fix those individual apps manually.
Reactions: Wanda
Nightly 101 & 102 Battery life.
After installing 101 it seems like my battery life has gotten much worse. Has anyone had this happen?
I use Incredikernel beta 8, so my battery life hasn't changed. Give it a shot and see if it helps.
Often depends on whether or not a particular app is hogging the 3g. Manage 3g (Meaning turning it off when not using) will yield significant battery savings IMO. Stock CM7 kernel has been working great for me. Running CM7 Nightly 104
Is there any way to add the people widget to this rom
If you mean HTC's people widget then no. HTC's widgets depend on the Sense framework, which CM7 doesn't have. However there ar alternatives, namely the widgets that come ith Launcher Pro Pkus. They do a great job of replacing most of the Sense widgets.
Nzone888
