[ROM][ICS][Aug 18, 2012] Android Open Kang Project [Stable 4]
Status
Not open for further replies.
Opening my PMs daily and seeing 3-5 pms bout "Where is your donation link? I really wanna donate!" so now its in the op for everyone who wants to. :)
I'll make sure you get a donation! But as for Stable 2...what's different from stable 1...?
Sent from my SPH-D710 using Tapatalk 2
We will be sure to add it to your website.. Coming soon... Whoops :-P
Sent from my SPH-D710 using Android Central Forums
Re: [ROM][July 30, 2012] Android Open Kang Project [Stable 2]
Stable 2 is up. Donation link has been also added. Ive gotten 50+ pms bout my donation link. Now its there. Enjoy guys.
Dark_Knight, been running your ROMs since I got my E4GT. On that note, you should check your PMs.
I'm new here. I've been on xda. Never knew about this forum. Anyways I'm dl this from now. Once I flash this following op instructions, will it have a safe recovery?
Ive never used mobile Odin so I'm doing it the long way and Odin back to el26 the get recovery then flash this. Can't wait
It's a great ROM... I was going to upgrade to the S3 but this rom made me love my phone again
Reactions: yaniel06
Here's a question. I can't find a good 600 pics in my gallery which I had. Where would they be? Also is there a sprint voicemail apk I can flash or dl? Would I be able to restore apps using titanium backup?
Re: [ROM][July 25, 2012] Android Open Kang Project [Stable 1]
Look above this post of yours on page 1 that I'm quoting Taco. Changing the setting in your build.prop file should fix the pixelation/tearing you're seeing.
Open build.prop in a text editor.
Find the line hwui.disable_vsync=true
Change true to false, save the file and reboot.
Does Stable 2 have this screen tearing fix implemented?
Status
Johno
