[ROM][ICS][Aug 18, 2012] Android Open Kang Project [Stable 4]
Status
Not open for further replies.
Just flashed this build clean, was previously running build 40 from xda. So far everything is much faster but the transitions in the app drawer and home screens seem a bit choppy. Is there something I can adjust to smooth this out? Edit: Never mind this seems to be smoothing out with use. I guess it just needs time to settle.
Also does this have visual voicemail or can I load the app from the xda veraion?
Re: [ROM][July 25, 2012] Android Open Kang Project [Stable 1]
Is anyone else having problems getting the startup tweaks to stay selected once you leave the menu for them? Logcatting didn't reveal anything helpful, at least nothing. I saw.
I too can second this issue. My startup tweaks will not hold. I didn't even notice until I read this post. Any ideas?
What tweaks are not starting????
Settings -> Rom Control -> Startup Tweaks
Nothing there will remain selected. If I leave that menu and return, my selections are gone. Tried fixing perms, cache and dalvik, redownload/reinstall, complete wipe of my device, and log at doesn't tell me anything helpful in that regard.
I will also like to add that super user never can gain root privleges upon updating the binaries..
Thats a framework issue. Ill look into it tomorrow.
Thanks again DK for all your help/effort
I just realized that I'm unable to send MMS. What can I do to troubleshoot? I've cleared app data and rebooted.
Re-flash ROM?
Sent from my SPH-D710 using Tapatalk 2
In my app drawer there is a few dead sectors...
Anyone what with this issue
Sent from my SPH-D710 using Android Central Forums
Play Store is giving me a hard time. I can't download any apps and it gives me an error when I try. I cleared data and rebooted. Ideas anyone?
Just installed...Any way to stop the text messages from syncing? Its loading every text message for like the past 10 minutes. Can I stop this???
Try removing your Google account, than clear data from Play store and google services framework than re add account
Ya, I I did that. The only issue I'm seeing so far is the rotating transition. It's about a 3 second delay.
Ahhh just found that option haha. Dark, ya did a damn good job on this!
Reactions: Dark_Knight2
Status
zulancu2
