[ROM][ICS][Aug 18, 2012] Android Open Kang Project [Stable 4]
Status
Not open for further replies.
So far its good. Smooth. Its new to me. Any suggestions on a recovery that's not twrp. Not a fan of touch recoveries
Sent from my SPH-D710 using Android Central Forums
Re: [ROM][July 30, 2012] Android Open Kang Project [Stable 2]
which kernel should i use from chris41g?
which of chris41g's kernel would be recommended on the Kang Stable 2? i tried looking around and for the most part i'm seeing 2.5 as the majority answer.
Can we just upgrade by flashing? We wont lose any info? And any info on a visual voicemail app? Also check your email Dark.
ok,
tried to install stable 2
installed just fine. installed google apps ... no prob...
this is the second time I have had this first was with the builds before stable
with the old modem...
I get this error...
( updating modem to s.fg20
script aborted) ( no error message) E:Error in /sdcard/fg20.zip
(status 7)
install aborted
any clue or pointer everything else installs no prob at all..:confused:
Try a different modem?
Reactions: byte1
ok,
I get this error...
(status 7)
install aborted
I agree...I loaded FG20 once and for some reason I noticed some random crashes... could have been just me but I've been flashing all of DK's ROMs with his original recommendation of FF18....no issues
Sent from my SPH-D710 using Tapatalk 2
Reactions: byte1
ty guys will give it a go..
DK
I'd like to let you know that startup tweaks still wont save when I select them and go back/reboot. :( like in stable 1
Also when chaning wifi and cellular signal colors, they will not change. **edit, wifi and cellular text color will change but not bar color, not sure if that is the expected result.
This isnt critical to me in any way, I just wanted to make you aware.
edit: currently running stable 2
i used the one he said ...the thing is this is twice now two different build and modems... same error i dunno :/
Probably a bad download on the modem. Try downloading it again, or better yet, just use the FF18 modem. I found the Boost Mobile FG20 modem to be a bit wonky.
I too switched back to ff18 from fg20. I experienced weird 3g connection issues along with 4g tethering problems after an extended period of time.
3g works fine for me.. but I haven't been in area to test 4g of fg20
So I am on stable 2. Clean installed. I try to open opera mobile. And it just exits. No force close or anything. So I figure I will pull a log at and check it out. Alogcat force closes and then when it asks me to report it force closes Google play store as well. I also tried using logcat viewer for the market and that fc when I try to read logs. Guess I will wipe and fresh install again.
sent from my BAD A$$ Epic touch
Well I fixed it by uninstalling opera. Then making sure it was being installed onto internal. Still don't know why I can't get alogcat to work. But oh well. Thanks dark
Hahaha ^ noob didn't read lol. Maybe if I actually read the open from time to time I would see deleting script 7 will allow me to read log cats.
Status
taoujdate
