[ROM][ICS][Aug 18, 2012] Android Open Kang Project [Stable 4]
Status
Not open for further replies.
How do I remove the Google search bar at the top?
Sent from my SPH-D710 using Android Central Forums
Thank u sir. Seriously impressed with this. Coming from CM9..u have made me like my phone again.
Reactions: Dark_Knight2
Except I don't have Google search app under applications
Re: [ROM][July 25, 2012] Android Open Kang Project [Stable 1]
Screen capture attached
try swiping left on the title bar where it says downloaded and such and tap on all and look there
Just a google service under "running" but has nothing in it about the search. Its only on the first screen so its fine. I thought it was on all the screen.
What widget apps would you guys recommend? Id like to have my weather widget back on my the main screen. I use beautiful widget on my tablet, will that also work on the phone?
Dark, please check your PMs.
I did not install the recommended modem as I was reading that it did not support wifi? Either way it seems i don't have 4G on he modem I am using.. 3G works fine, downloading at 1.5mbps
Wifi is in kernel not modem I'm pretty sure
sent from my BAD A$$ Epic touch
You are correct, WiFi resides in the kernel (driver compilation). Modems will not change WiFi characteristics.
Cheers
Reactions: patrao_n
Awesome. The only problem I am having is the camera. Sometimes it works and sometimes its unusable. It won't force close until I try to push home or back to get out of it. If I try to use it again it sometimes works. That's my only problem I know of. Thanks for this dark :)
Status
mohitsl
