[ROM]MIUI GingerBread Release5 4.26.2012 ZVD
I'll upload some pics when I get home. :)
Sent from my LS670 using Tapatalk 2
Oh, what did you do??? Also Jason, we should add more icons to the default theme.
Apps without themed icons look kinda lame and little :D
Also, can we add beats icons to the music notification?
EDIT: Did it :D Might add in next version if others want it.
attachment.php
Beta 2, Notifications tend to vanish with no interaction, (X) button to clear notifications unable to be seen. Music does not populate and gallery crashes (tried to un/remount SD card and refresh both to see if that made any difference. It didn't). Themes don't work (already saw post about lockscreen theme fix and such) which is the main reason why I love MIUI so much (the transformers lock screen? Hell yeahs) Headset is a bit wierd with audio and... my biggest issue is with the app list. User/SD Card/Running. Cyanogen9 has it as On SD Card/Running/All Missing the ALL portion of that prevents being able to either move apps to the SD or force stopping them through that menu. Not sure if "User" is supposed to be the "All" portion of it, but seeing how it didn't populate with any information makes it seem otherwise.
Pretty speedy overall but not the MIUI style I used to know and love with my MyTouch 4g (before it got stolen)
Though it is still just a beta I hope this grows alot more as a rom and gets some good polish on the side.
Till then, back to CM9 for me :(
Beta2? I never mentioned any betas. It's currently release 5 (Straight and experimental versions). If you tried the later and had problems (I didn't), try the original version.
I neither have problems with notification not the X symbol. Music populates perfectly and gallery doesn't force close. Apps populate properly on all the 4 sections. Moving to Sd however causes random reboots and is mentioned in the OP/2nd. Theme fix is mentioned in 2nd. Your download might have been corrupted, none reported the issues you mentioned above.
attachment.php
Click to view quoted image
I think he might have replied to the wrong MIUI thread ;) The other one is beta 2 and it seems that a lot of things aren't working yet.
I love you ROM, pretty much everything works! The reason I haven't tried CM9 yet is because some things aren't fully functional yet. I like to have everything working on my phone:D
Last night on the stock lock screen there was a screenshot option when I pressed the power button. It's not there anymore, any ideas? lol
Uh uh, now I understand. Thanks for clearing that up. :) I'm glad you like it but don't hesitate to mention if you could think of any improvements we can try to achieve. About the lockscreen, I can still see the option. Did you change anything? I'll try to dig and see if therez an option for that.
I'm using MiLocker now so I can't see the power option anymore. So it's only there on lock screen? It's not a big deal though I have another screenshot app. I like the idea of adding more icons though:D
Yeah, just disable Milocker and check, it must be there. Andross is pretty good for screenshots.
trying experimental (5) version now, camera didn't work for me on both versions decided to r/r camera from r3, works great now.. the only issue so far is the lack of stock email other than this overall performance is increased over previous versions and feels stable...
Woah, what governor you are using and how much did ya overclock to.
Whats the widget in the first pic?
About the email, just pull from the straight version and push to system/app, set permissions, reboot. :D
So yeah camera froze again... The camera app from R3 works? Where can I get it? Thanks~
nothing just porting over a meizu 9 theme to work for our version :D
plus, some xml needs to be edited in the music app. the mask is off cause the album art is too big, my only problem is that i can never get miui music version 3 to decompile correctly...it always comes up with errors. i know how to fix it cause i've fixed it in version 1 lol
if you use the compact notifications long press power will work as normal.
Reactions: carole6m
Awesome J :D Can you hook us up? And bro if you have any ideas of making your own theme or even an icon pack, would you take some icon requests? :D
That one is the CM7 camera?
Yikes, I don't remember. It could be :-[ I remember including Cm7 camera in one version. I shouldn't be deleting the release notes I guess.
i have a few ideas, one theme i am currently working on, a port of my orion theme just to test the waters. for icons, i've been using the vexellium icons from xda...i just apply the icons. i'll upload a copy of the meizu thing if you'd like, once i fix a few graphic things that didn't transfer over.
I would love to try that out. :)
matsatoknifebuy
