[ROM]MIUI GingerBread Release5 4.26.2012 ZVD
i have a few ideas, one theme i am currently working on, a port of my orion theme just to test the waters. for icons, i've been using the vexellium icons from xda...i just apply the icons. i'll upload a copy of the meizu thing if you'd like, once i fix a few graphic things that didn't transfer over.
I like that Orion theme :D
Woah, what governor you are using and how much did ya overclock to.
Whats the widget in the first pic?
About the email, just pull from the straight version and push to system/app, set permissions, reboot. :D
InteractiveX 245-748
Dithering =off
animations= some
widget is Android Assistant
Yes Sir, added email app and all is good
thanks for your (and others) work on this rom I am really appreciating it
Reactions: Invincible Madness
Dithering =off
animations= some
How'd you set dithering off? Did you include something in the build.prop or is there an option in settings that I don't know.
settings-system-cyanogen settings-performance-enable surface dithering
dont use or like to use millocker for setting lockscreen, stays in memory all the time even when not needed, there are a few lock-screens that are sized for our phone and work well when applied from 'custom theme' just have to search for one and apply, if you get stuck on one you can not unlock... try holding the 'back-key' down while clicking 'volume up' to bypass screen... works nearly 100% for me but occasionally keys will switch and find holding 'search key' down while toggling 'volume up' works... oddly enough after setting my lock screen up using the above toggles i can now press menu button only to unlock
'a tip from your uncle Ebb'
yeah i always tweak that out and the virtual memory usage to 48mb's I always run 826max 600 min with on demand.
oh and nice theme porting, I would love to see a about 40% black transparent status bar pull down instead of the white with black status bar (primarly black theme with white/grey or orange text is sweeet!
Is it normal to not be able to restore apps from titanium backup
Sent from futuristic optimus s
I restored apps too. I'm doubtful about a few apps though. Some of them refuse to install and may be restoring THOSE apps might not be working. Otherwise, it works well.
dont use or like to use mill locker for setting lockscreen, stays in memory all the time even when not needed, there are a few lock-screens that are sized for our phone and work well when applied from 'custom theme' just have to search for one and apply, if you get stuck on one you can not unlock... try holding the 'back-key' down while clicking 'volume up' to bypass screen... works nearly 100% for me but occasionally keys will switch and find holding 'search key' down while toggling 'volume up' works... oddly enough after setting my lock screen up using the above toggles i can now press settings button only to unlock
I still haven't figured how'd u manage to crank up the score to 1300 :D Mine doesn't an inch beyond 700. May be each phone is different.
don't think there should be that much of a difference...you have mail
check you PM
I tried restoring tapatalk and it says application not installed
Is it from the market or downloaded? If later, did it install on previous versions (I'm guessing not). Had similar issues with Lewa that some downloaded apps wouldn't install. Not sure what the issue is.
Hmmmmm lemme know when the issue is fixed
I tried Release5 last night, and I could not get it to boot. I tried at least 5 times. I finally decided to try Release5Exp, and I finally did get it to boot however, whenever I had an incoming call, my phone app would force close and I couldn't answer. I'm not sure what happened. I reverted back to 3 or 4 I'm not sure which one. I think 3 because 4 wouldn't let me login to my google account. 3 seems to be super solid no problems at all. One feature that this ROM has that I would love to see work is the "reject with SMS" option upon receiving a phone call, every time I have tried I get a force close. I'm not sure how feasible that would be...but I would love to see it personally, and I'm sure others here would agree. Just reporting back on issues. Thanks for your work. I really appreciate it.
Not sure, why phone is force closing for ya. Another person who tried Exp didn't report either.
About experimental, I'm running it since releasing and it's running fine. You might want to reboot into recovery, wipe cache, dalvik and fix permissions under advanced and see if that works. One more person tried exp and reported no such issues.
Regular build, if you want to try again, wipe clean, flash rom and gapps, flash both again on top. That might get it to boot. This was an issue on previous build and was actually fixed for others. About the reject with sms, i haven't tried it yet but will look into it to see if it can be made to work. I'll try my best.
Reactions: twtippets
Ok, fixing permissions apparently fixes everything. Haha. Thanks for the tip worked like a charm and am now running Release5 with Lego Theme that I just happened upon. Runs awesome.
So I'm using experimental version 5 and the only problems ive had were:
Hardware lights staying on at launch
(They stay on until i hit the power button on and off a couple of time)
Hardware lights stop coming on after they go off
(Not complaining at all about it lol)
Camera isn't found after taking a photo
(Fixes after a reboot but break again and i can't install the v3 camera)
White text on white background for some app popups
(Nothing more to that)
Theme isn't working for me
(Even following the instructions in the 2nd post when installating it loads about 5% then says it's installed
Edit: I cant change anything now, tried to set the lockscreen wallpaper using a photo from my sd card and it failed)
MMS not working
(I read through the thread but couldn't figure anything out and im getting the 9109(?) Error)
I dunno if it helps but i could use themes til I installed a theme without unchecking everything so i couldn't get it to unlock, when with the menu button + volume button tip, so i did a full wipe and reinstall. I was thinking of trying release 5 but i honestly like this version a lot.
Can anyone give me any advice? Gonna try a complete reinstall.
Edit: tried doing a cache and dalvik wipe, dalvik came back with an error saying it couldnt wipe then said the wipe was complete.
Also thanks for all the hard work that went into this rom, its mmy first time with MIUI and I'm digging it so far :D
MMS not working
About hardware lights, don't set auto-brightness on, try moving the brightness slider a little.
Camera is working for few not not for others. And why isn't V3 camera installing, did u try installing it as an app? If so, don;t do that, instead push the V3 camera to /system/app, set the permissions and reboot. While you are at it in recovery, go into advanced and fix permissions. You 1st said themes aren't working and then that you got it working, so I;m assuming you got it to work. About lockscreen wallpaper, place all the pics u want in /system/media/theme/lockscreenwallpaper and now apply from theme manager.
Let me know fixing permissions helped MMS. I don't use it but people reported it to be working.
dumpsterrentals89
