[ROM]MIUI GingerBread Release5 4.26.2012 ZVD
About hardware lights, don't set auto-brightness on, try moving the brightness slider a little.
Camera is working for few not not for others. And why isn't V3 camera installing, did u try installing it as an app? If so, don;t do that, instead push the V3 camera to /system/app, set the permissions and reboot. While you are at it in recovery, go into advanced and fix permissions. You 1st said themes aren't working and then that you got it working, so I;m assuming you got it to work. About lockscreen wallpaper, place all the pics u want in /system/media/theme/lockscreenwallpaper and now apply from theme manager.
Let me know fixing permissions helped MMS. I don't use it but people reported it to be working.
I do have auto brightness set off but i still have the issue but i did try and install it as an app since i dont have a real computer to speak of atm. But once i do i will try to push the camera and fix permissions. Themes still wont install, they aren't found when placed in the 'system/theme' folder but they do in the MIUI folder on the sd card but dont install. I did a clean reinstall so ima try the permission fix then report back.
One thing. It's not /system/theme.. it's /data/system/theme
Don't confuse the system folder in the root with the system folder inside data folder, we need the later.
Reactions: zatioichi
i only needed the theme folder in data/system
themes change from the folder on the sd card.....never needed to put them in data/system/theme.....
So I'm using experimental version 5 and the only problems ive had were:
White text on white background for some app popups
(Nothing more to that)
that is usually caused by the offending app. most likely the text color is coded in the layout and not as a style....
Yeah sorry about that, i did mean the data/system folder, first time i placed the themes there they didn't show up in the miui theme at all. So ill try that again, sorry im kinda busy so im a bit slow. Thanks for the advice, hopefully i can figure it all out.
No worries. Again, like Jason mentioned you just have to create a folder, don't have to place themes in it. You just have to put them in your sdcard/miui/theme.
Oh nice! Cool, thanks so much for all the help guys, i can't wait to see more from A.P.P its so awesome to be back on CM7.
Does anyone else have the problem of always having a voicemail notification in their notification bar? If so how do i get rid of it? Thanks.
I'm using youmail for voicemail and no problems here so I'm guessing you're using the sprint voicemail. In that case, someone using it might be able to help.
"gingerbread madness" catchy rom name
Eh! More like MIUI Madness? :D
gapps-20111214-with.VVM.fix.zip... ...worked for me,, some don't like using this one because it interferes with themeing messaging, but it should get rid of the annoying voicemail message
great rom BTW
Reactions: twtippets
I tried it with no luck, still a voicemail message :-\. Oh, well it may just be my phone? I did apply the MIUI mms.apk and that worked really well, thanks for that tip I was wondering what happened to my MIUI messaging.
We have the same issues with HydroROM only our issue is black text on a black background. Very annoying but there isn't really much you can do about it short of modifying the offending app itself.
I had did this on a clean install.... but should work if cache, and davlik cache is wiped before installing...currently experimenting with ice cream sandwhich and have same issue, and for this since this is no fix... i force close VM and delete the message from messaging.......
UGH. I finally found it.
To save time...
"Limit to one forum bump per day"
MEGA-BUMP.
YOUR WELCOME OPTIMUS S MIUI ROM USERS.
dumpsterrentals89
