[ROM]MIUI GingerBread Release5 4.26.2012 ZVD
Please please please!!!!!! Make homescreen landscape mode .....it the only way I use my phone since I only have wifi I totally like this rom but it why I switched back to kravens cm7.2 .........please.........ill be your friend
God I love the options this has!!!! Awesome
Also how come some app when I install them acts like I didn't install? Are they incompatible?
I forget Wich ones off the top of my head but there was a few of them. Like I said I'm back on cm7.2 now so I can't retry to be specific. At least for now.
As much as I'd love to do those, I sincerely can't. MIUI launcher simply doesn't allow landscape and it isn't simple tweaking of code. It would require all the images stretched to landscape and much more that I don't know. You could always use a different launcher like adw.
I saw that flash doesn't install, can't think of anything else.
Think ill try a different launcher see what happens. Just curious about flash where does it?? Have its hang up?? Or is this unknown?
Anyway thanks for thinking about it and good work truly a work of art I'm impressed
Trying a diff launcher SHOULD work.
I was talking about the adobe flash player. It doesn't install, may be incompatible. I'll have to do some research on that. And thanks for the kind words, it means a lot :)
Added an Experimental Tweaked Version to the OP (nand before trying)
Download Link http://db.tt/QCsxrGjh 68MB
Removed most media files, bootanimation, some widgets. (148MB free memory)
Added some tweaks (Leave feedback if you find Issues/Improvements)
Changed In-call Background
Before and After Tweaking, both oc'd to 748 with SmartassV2 :cool:
attachment.php
attachment.php
would cm7 themes work with this like the sense theme jasonevil made
Sent from futuristic optimus s
I don't think so, I may be wrong but I think MIUI has a different framework. Sorry.
So, I was playing around with the camera. It seems that the camera works when using the stock camera app. I haven't had any problems there. When I try to launch the camera in a third party app( i.e. Pixl-r-matic, or Instagram), it closes and won't work at all, even with the stock app, until I reboot. I am thinking that there is something in the third party apps that is coded differently that makes it close or malfunction.
Has anyone had any luck with WIFI or USB tether. I can't seem to get it to work. I can get it to show and I can get my computer to connect to the signal, but then I can never get a valid internet connection or any pages to load. I used stock USB tether and FoxFi. Any other programs to use?
Wireless tether for root users version 2.0.7 works
Sent from my LS670 using Tapatalk 2
Reactions: twtippets
Camera works for me too. Doesn't freeze anymore. Default lockscreen doesn't show up anymore when I'm using MiLocker. :D
On 4 stock lock screen didn't show up for me. Now milocker fights to show up with stock lol
using R5 or R5-exp?
Anyone tried Exp version??
lol
It was the case when I had R4. Every time I woke the phone it showed the stock lock screen. I had to turn off lock screen from power options a couple of times to get MiLocker lock screen to show up and if I rebooted I would have to do that all over again.
Forgot to upload a snapshot. Love the improvement! Especially now that the camera's working! Having to reboot every time after I took a picture was frustrating lol
attachment.php
dumpsterrentals89
