[ROM] TrulyEpic Rebirth v1.5 AC - no planned EB13 update :'(
Did TER1.5 replace the email app from 1.2? I liked the email layout in 1.2 better with the preview function. I am using Mini theme 1.8. Is it possible it changed it?
Paul love your work in the new 1.8 theme. One small thing I have noticed is that since I am running touchwiz with your icons the messaging icon you blacked out is just a tad too small. I think with the touchwiz it lays the black over the green possibly? Anyway I have a little green halo around that icon on the bottom dock. Was that intentional or is there anyway to increase the size of that icon a few pixels?
Edit:
Nevermind: I'm thinking it was intentional now that I removed the messaging icon from the dock. I am just running a totally black/white thing and it stands out because its the only color on the home screen.
See post #2, under Customizations.
Edit:
Yes I took a green messaging app icon and applied black over it so it did leave a bit of green showing threw as a glow around the edges which I thought actually worked well with a dark background. Plus I added a drop shadow effect on the custom icons.
Try downloading AdFree from the Market. There should be a "revert" button in the app that will remove ad blocking. If that doesn't work, post here and I'll make a flashable zip for you.
Worked like a charm. Thanks again Rag. Sorry to hear you won't have time to keep working on the rom, but as I said in my last post 1.5 is so good I can't see myself swiktching for quite some time.
anyone have any idea why i odin to stock dk28, i can send MMS. I then reroot and CWM 3 and then install truleyepic and i get no MMS anymore. I have tried bonsai and same response.
See Troubleshooting, 1st post. I think it's called "Problems Receiving MMS."
If that doesn't work for you, you can also flash the stock SMS/MMS app in the 2nd post.
Download and flash the Galaxy Tab Email, 2nd post.
Reactions: svx
NVM, answered later on.
Thanks Paul, I saw that there was a change under Change Log, but did not know what to revert to. Will flash Galaxy app.
Just noticed that WiFi Tether build into TER 1.5 is FC'ing upon reboot and will not open when selected. WiFi is off by default on my phone. Is this app starting on boot? Wouldn't the app prompt me to turn WiFi on when it starts rather than FC'ing? I did not have this prob with the version from the Marketplace with TER 1.2.
Here is the error I am receiving:
" The application WiFi Tether (process at.mysandbox.android.wifi.tether) has stopped unexpectedly. Please try again."
I noticed this error occurred both after an upgrade from 1.2 to 1.5 and from a clean install (factory restore, wipe, TR 1.5 Clean).
Any ideas?
well... after realizing that i was still running v1.2 and the old version of the mini theme last night. . . i finally updated haha. and wow. i thought i was happy with TER like it was. sooo much faster, better battery life, all the little bugs that bothered me (but not enough to be a big deal) seem to be fixed. EB13 support or not, im staying with TER. I love the way the phone looks and feels, and i'm not giving that up to go back to being sprints slave. for what i pay a month for this phone (on top of my family plan), i deserve to have it run and feel exactally like i want. i love it. thanks Rag. :)
another question... how can i edit icons?? (and not only icons, but icons in the dock/tray whatever its called on the bottom of the screen) I want to use the lil android guys holding the different apps.. but i cant figure how to edit icons on adk
Any ideas?
Yeah you need to update Wifi Tether. Go here:
Downloads - android-wifi-tether - Project Hosting on Google Code
Download the 3.0 Pre 9 it works great.
Reactions: mjbelknap and svx
i can receive no issue just not send
Still the same Troubleshooting for can't send. You have to change some settings. It's in the referenced post.
from the no bubble mms thread:
"you need to go into the Mms settings and under "Custom User-Agent" select "Custom" then enter any name you want for the custom user agent... You might need to restart the messaging app, but I tested it and was able to save at full 2560x1920 ..."
Reactions: ragnarokx
I have no complaint. Looking back I was going a little overboard trying to make my home screen stark Black/White :)
You have a couple options. You can theme the icons, by changing the .png files in each one, or the easier option: use a launcher like ADW that allow you to change icons on the fly.
I discovered ADW last night. I was nervous at first because I didnt want to loose the feeling of the drawer, the 4-D vertical slider thing, with the 3 icon dock on home screen... but I was able to configure it perfectly with ADW EX, and got the little android dude icons i wanted :) (the ones with the lil android robot holding the different icons. if anyone wants the pack shoot me a pm with your email and ill send it to you. it took me hours to find a download with them). next step- install genocide :)
So, I am running TER 1.5 with mini theme 1.8. I downloaded and installed the Sprint Nascar app from the link listed. I got it installed, but whenever I try to get it running, it says that I must be a Sprint/Nextel user. Is there any way to get this working?
byronsss
