[ROM][WIP][PORT]Paranoidandroid from optimus one to optimus s
So just outta curiosity in the original paranoid android thread it says something about auto screen Res? Does this mean it'll run games better without screen size issues?
Or hopefully anyway.....
Sent from my LS670 using Android Central Forums
Hopefully that gets fixed, when I was trying to read a book in Aldiko I couldn't get the words to appear right in any DPI. Switched back to Kraven and the books read fine.
Yeah me too its the #1 thing about this rom 2nd would be the tablet ui I'm a full time wifier so it'd be perfect:thumbup:
....so long as flash works people say flash sucks on os but I have no complaints
I saw an APK for ICS flash on here but most of those are really 10.2 or 10.3 (Which does not work properly, if at all, on ICS)
Whether flash does or doesn't work though is not a problem for the ROM developer though, It's a problem for Adobe.
Sent from my LG-LS670 using Android Central Forums
Well adobe is done with flash on Android so its all good.
IV heard that before how could that be?!
What would we use to stream video
Like www.wtso.net and such flash is important to the end user
However I have no complaints if they or someone does something new/better
Flash is only important to the end user because people make it so, however, Video player apps on Android do not rely on flash and most sites are switching to HTML5 for cross platform mobile video supporting both Android and iOS.
Also, I don't think data works, but then again I can't test it because of how I use the handset like a minitablet with no service.
Ill have to disagree with you though because 90% of streaming content is still based on flash when I heard adobe was discontinuing flash I was like WTF!!!
I like html5 better but all my favorites are still flash so I guess I'm biased
:p
I don't think data is working either
:p
Found a replacement for Aldiko for this ROM, Try Moon+ Reader, you'll have to get it from their website though as it doesn't show in the market.
EDIT: Build prop needs modified as the phone is showing as a P500
Sent from my LG-P500 using Android Central Forums
Reactions: vernotzy21
I LOVE MoonReader +!!! Such a good alternative to Aldiko
First time I tried it and I have to agree. I'll upload a LS670 build prop soon.
EDIT: Here's a LS670 build prop that uses parts of Kraven's CM9 build prop. Just take off the .txt extension and push it to /system/
You'll want to clear the cache/data of the Play Store and restart though.
Yes. Use CAI build.prop and data should work fine.
I just modified the ROM's build.prop with some values from kraven's :-). Works great now
EDIT: OP, Rom works great. The reason there's no 3G or Mobile Network (or calling with the SIP stack) are because you used a GSM-based ROM on a CDMA-based Base Rom. Port from a CDMA based ParanoidAndroid and everything should be working perfectly, it would even stop the force-closes we're getting. (If your no longer updating this ROM, can I ask how you ported it?)
Wait so it has tablet ui and most things working???
Looking for good cm9 or cm7 themes??? visit this site for good themes. http://forum.digitalhouseoftreats.com/
1 thing about porting, never use a different build.prop not for your device. If you port from a CDMA device, results will be the same. Force close, and no tablet UI
Is it possable to just remove GSM files and replace with cdma? Or is it more complicated than that?
Is this a modded paranoid.prop
ezmoving
