"unfortunately contacts has stopped working" -- grrr
And me. I've cleared the cache and done a full reset. Only put basic apps back on that were all there pre lollipop update. All was well before that. The problem still persists oh and my alarm clock doesn't work either now. Does anyone have any ideas?
LuciH, make sure your pictures, etc. are backed up to sd card or cloud and do a factory reset (you'll probably lose txts). It'll take you to the base lollipop version which will fix the alarm clock issue, battery draining, and speed. It, however, did not fix the contacts issue. I'm so trying to find a fox for that too.
Mine has been doing this to. In fact, I updated a contact and later on the data was lost. Tried a third time... See if it works...
Puzzled
I'm having this problem as well; it's occurred ever since I got the lollipop update. I've reset, cleared the cache/data and it still happens. I wonder if this is also connected to the seemingly random changing of the background on my phone back to the default.
If anyone has a solution, please tell me.
I ran across a tip..
I disabled Google+
No problems since. However, it sucks because I'm one of the 10 people who use it!
I've been having this same problem for about a week now. Ran across the suggestion that it was related to Google+, and the recommendation to disable it. Did so today and restarted. OK so far, but since it was so random regarding time, the best I can do it repost if I see the warning again. If this indeed turns out to be related to G+, I hope Google gets to it soon. Like bontjes, I'm another of the 10 that use it...
I disabled my google + this morning so we shall see. That leaves what.. 7 people using it now? Lol!!!
If this fixes the issue than hopefully we get an update to Google + soon
Verizon Note4 w/ Otterbox Defender
I have also had the problem with Verizon note 4. I still use google + as well, but mostly for picture backup. Instead of disabling, I instead uninstalled all updates as I only started having this problem recently, and figured I must be a recent update (I hope). I will let you ya know if it works.
I've disabled google+ 2 days ago and I haven't seen it since. It used to happen several times a day. We'll see.
Well....10hrs now....no errors, usually don't go by more than two hours without getting it. So far so good, will update tomorrow. But so far it looks like you only have to uninstall updates instead of disable.
mayamalamadingdong
Well its been two days, seems like uninstalling google + updates has worked. Guess will have to wait for a fix from Google before updating again.
Mine stopped after disabling google +. Hopefully the send an update out soon
Was happening to me too. Thought it was just my phone. Unfortunately I can't disable Google+ as I use it quite a bit for beta testing and several Communities I'm part of. Hopefully this gets fixed soon.
via Note 4 on Verizon Wireless
Technut, just uninstall google + updates. That's what I did, still using Google +, and no errors on the note 4 for 3 days now.
wobblefix
