Verizon Fascinate: Tools and Quick links - PLEASE Read post#1 before posting in this forum
Re: Tools and Quick links:PLEASE Read post#1 before posting in th
What builds will this work on:All builds (Does not work with froyo)
What Downloads will i need:
One click zip file
FascinateRoot_v02
Directions: (Assuming you followed preparations from Post #2)
With your phone in debugging mode set to stay awake
1.Extract downloaded FascinateRoot_v02.zip file directly to your C:\ Drive
so that it looks like this C:\FascinateRoot_v02
2.Open FascinateRoot_v02 folder
3.Double click START_ROOT
4.Command window will appear
Carefully read all directions
hit any key when you are ready to continue when prompted
After the first reboot a pause has been added for the SD card to mount
and for you to disable media sync by pulling down notification bar
hitting media sync,then disable
5.When the process is done it will say Complete. At this point
Hit CTRL+C, unplug and restart your phone. download titanium backup,
If it asks you for Superuser permission you have successfully rooted
Instructions with Visual Aid (Provided by gunnermike53 )
Congrats.
Trouble Shooting
During process it can not push file because it says file not found
A file in the FascinateRoot_v02 folder is missing or corrupted. Download FascinateRoot_v02.zip file again. and restart the process.
adb push: Permission Denied
SD card is mounted to your, if the sdcard is mounted there is no way for the adb to push files from your computer to your phone and on to the sdcard.. please drop down notification bar and turn off usb storage Close out and start again
Prompt tells you that you do not have permissions
The process failed to grant you temporary root access. Close out and begin again.
After continuing from reboot the process freezes for a long time
This is common, best way to handle this is to be patient some phones take 5 minutes other take up to an hour. If you lose patience move on to a different method or try again. Most times waiting it out will lead to success.
Error Device not found
If this happens after continuing after first reboot, this means that the phone was not properly connected before continuing. After reboot unplug the phone, plug it back in, disable media sync, mount then unmount SD card then continue.
Additional Conditions to check
1. Check to make sure you installed the Samsung Drivers
2. Make sure your phone is connected using the original cable that came with the phone
3. Verify that debugging is enabled.
4. Try to run it again
5. If you are receiving errors then your phones drivers were not installed
6. If you are having a different please post here so we can help you.
i was fully rooted until verizon pushed an update to my fascinate......now i lost root access. tried to reroot using exact procedure and it wont take it. it will not push any files to the phone. it says 0 bytes for all. then after it does that it says successfully exploited installing root files and deleting temp files...............then says mount: operation not permitted followed by a bunch of "cannot creates" and "no such file directory". help, nick p:(
When i powered up my phone i now have a different system on it. The majority is the same but my drop down menu and market are different. I have the verizon samsung fascinate. i dont know what version i had, but i would like it back lol. Im failing hard at trying to root.
why my phone still error device not found when process rooting?
i have installed new version driver from official website.
what wrong?
I'm having this same issue and now cannot even get ODIN to see my phone to load DL09
Anyone?
Also the links to the Samsung files are no longer valid in this post.
Update -
I reinstalled the Samsung drivers, even though they were already installed and working prior to 2.2.2
I'm now back in ODIN and loading DL09 to bypass this lame update. I'm hoping that the OTA doesn't force 2.2.2 once I'm done and that I can find a good copy of 2.2.1 to load.
Update 2- OTA is going one at a time so im now loading 2.2.1 then telling VZ to suck it on 2.2.2
what wrong?
Need more details please. When are you getting this error? What are you trying to do when you get this error?
I have tried to root my phone and followed the steps listed in this thread. everything says it completed yet I Titanium Backup says it doesn't have root access.
Any thoughts?
Man the restored part saved my life my phone was bricked for a whole night not a good feeling D: ilove thiss!
I used Odin to flash CWM and now it is stuck in recovery mode everytime that I boot up. I have tried all options in CWM and nothing works, can't get past it. Need big time help. Thanks.
What builds will this work on: All builds
The Following file is to be downloaded and put on the root of your SD card
My modified ChainsDD superuser +busybox package
http://adrynalyne.us/files/odin/su-2.3.6.1+busybox1.19.zip
So use the directions in post #12 of this thread to flash via odin.
But Use this file provided
The Odin package of Clockworkmod recovery:
CMW Recovery All
Now once you have flashed odin (use link i posted to walk you through it) and you have downloaded su+busybox and put the last to file to the base of your SD card. Do the following steps
(Do not allow your phone to turn on!! boot directly into recovery) Reboot into recovery>VOL up+VOL dwn+ power, you will see the samsung logo cycle twice, on the second time let go
From here using the vol keys scroll to install zip from SD card , use the power to select.
scroll to and select choose zip from sdcard
then scroll down to and select su-2.3.6.1+busybox1.19.zip
scroll to and select yes, this will install the zip
once its done hit the search button to go back
then select reboot.
you should be done and rooted
Good luck and enjoy
Does any of this work with Froyo???
One click zip file
FascinateRoot_v02
Directions: (Assuming you followed preparations from Post #1)
2. Now go to your start button on your menu bar,in the run field or search field depending on your version of windows, type CMD and hit enter. The command box will present itself. From here on out just copy and paste the commands i will provide below. To paste in the command box you must right click on the mouse and select paste. Do not paste BOLD text below those are just for info.
Commands are as follows:
cd C:\FascinateRoot_v02
adb devices
It will state
"List of devices attached
I500******* device"
If you dont see this you are not connected
adb push rage.bin /data/local/tmp/rage.bin
adb shell
cd /data/local/tmp
chmod 0755 rage.bin
This step is important. After you type the next command there will be a pause and you will have to wait until you are kicked out of adb shell. It is important you do not touch your phone or type anything in the command window. If you do don't worry, nothing bad will happen you will most likely have to pull your battery and try to run the command again. If your phone doesn't lock up you can probably unplug it and plug it back in and start back at "adb shell"
./rage.bin
After several seconds the $ prompt will come back
After another 20 seconds or so you will be kicked back to the C:\FascinateRoot_v02 prompt.
adb devices
If your device is still connected proceed,if not give it a min or to and type adb devices again. if the phone is locked up after a couple mins battery pull and start over.
adb shell
You should now be at a # prompt
This mean you have achieved temporary root on the device.
exit
You should now be at the C:\rootfiles prompt again
Type the following commands:
adb push su /sdcard/su
adb push busybox /sdcard/busybox
adb shell
mount -t rfs -o remount,rw /dev/block/stl9 /system
cd /system/xbin
cat /sdcard/su > ./su
cat /sdcard/busybox > ./busybox
chmod 4755 su
chmod 4755 busybox
exit
You should be back at the C:\FascinateRoot_v02 prompt
adb install Superuser.apk
It will now install the Superuser.apk this may take some time while it installs when it is over it will say:
Success-after you see Success hit Ctrl-C Then reset your device
3. You have now achieved Root, congrats. If this didnt work for you well then :confused: time for a different approach.
Here is a screen shot of what i did, you will see some mistakes i made... and at the end it says failure but i had already manually installed the Superuser.apk so thats the reason for that. this is just to give you an Idea of what you are getting yourself involved with.
GOOD LUCK!!!!
Trouble Shooting
After installing Superuser.apk States Install failed already exists
Chances are at some point the apk was downloaded from previous attempts to root your device. Just ignore proceed to reboot device. Download Titanium backup, open it and see if it asks you to allow or deny Superuser access. if these options come up means you are rooted. If not try the rooting process over
After typing in:
it keeps saying cannot create ./su: read-only file system.
Does anyone have the busy box / superuser file link that's still active?
I cannot get it one to work.
Tried several times to root the phone, but keep getting this while it tries to finish the rooting.
Use the CWM from the link below and the su + busybox file in post #2 by killahamsammich in the thread linked below
Forget one click rooting or any methods like that. Follow the instructions by killahamsammich in post #2 of this thread:
http://forums.androidcentral.com/ve...15309-help-needed-root-fascinate-w-froyo.html
His link for the CWM file is dead, so use this CWM:
CWM3_Voodoo.tar.md5
Reactions: bendrexl
Hello? Has anyone used Post #4 ADB rooting recently? Does it still work on the Samsung Fascinate phone with Froyo?
No. One click root methods do not work on the Fascinate anymore. Follow my instructions from the post above.
Anyone have any rooting instructions on froyo 2.2.2 ?
Quick Question, i followed everything as instructed. But when I rebooted my moble data wont connect. I can call people and text but I cant get on the internet or facebook etc. any advise????
Kenny Fluent
