Where is the 4.3 Update for the Verizon Galaxy S3?
Only thing I have noticed that I don't care for is how long it takes for the screen to come on. Once the screen actually comes on this thing flies lol
Sent from my SCH-I535 using Tapatalk
to turn off your "tabs", go to the bottom left "key" while you are in settings, and you can toggle the tabs off and on.
Are you sure you have a Verizon phone? My S3 does not have an option to turn tabs on/off. I have not done the update yet.
Are you talking about when we see a white screen with the Verizon logo for what seems like a half hour? Lol
It's only available after the update
It just defaults to list view and we had missed that you could swap it earlier.
Verizon removed the Tabbed Settings... Ugh, Why? At least you can get rid of the Persistent Wi-Fi notification.
Reception still terrible :-( :-(
Doing a Factory Reset and then will check it out in more detail.
The screen does look better, though, I give them that (Colors, etc.). The Auto-Brightness seems more aggressive (better calibrated?).
I wonder if S Beam still turns itself off randomly and on every reboot...
If you hit the menu key while in settings you can toggle on the tabbed settings option.
Edit: this only works after the 4.3 update
After updating I still don't see an option to turn "tabs" on.
Hmm that's odd. Mines does it
That's the only way I could find to show something Verizon and the tabbed menus together lol. The backup assistant
Those of you who've lost Swiftkey and had to reinstall: Did it forget your Swiftkey settings/history? The beauty of Swiftkey is that it learns from you on the fly and many unique phrases are automatic for me now. Will this be lost?
I did notice that :-) I love that I wish they would've left the mobile data as well though its not that much harder to get to it though lol so it doesn't bother me too bad.
http://img.tapatalk.com/d/13/12/19/asatama9.jpg
Thanks to you guys I found out something pretty cool for the Settings part of this phone. I downloaded and installed this update once I got home from work so I could use my WiFi connection and save my mobile data. So far, I'm loving the update and this change in the Settings is pretty cool. Note to Verizon: I LOVE THIS. PLEASE DON'T YOU DARE CHANGE THIS IN SUBSEQUENT UPDATES.
I don't think that is true that the update counts on your data. I asked them about this once before. It is the same as if you call about your bill or support they don't count that call against your minutes.
My friend that works for Verizon said that it doesn't but I only had a gig left for the month so I didn't want to chance it so I used WiFi lol.
Wrapcart
