"Whole" Punch Makes a Notch Seem Good
Re: Whole Punch Makes a Notch Seem Good
In real life, it looks way better than what you think. I had some time with it and it was a non issue. Dont even see it
The look isn't my biggest issue. I still think that it is a little stupid, but I would be able to tolerate it if they hadn't removed the iris scanner and the led notification light
You find a notch which is 20x the size of the holes we're talking about to be less noticeable or intrusive than a small hole(s) on the top right of the screen?
That's a real head scratcher.
Well the notch is at the top of the screen and not in the screen
Doesn't impact app content since they can't use that area anyways. Media you have a point, but it it still letterboxed because of the aspect ratio anyway. I'm not sure how you propose they would calculate the screen size with that area removed, since screen size is a diagonal measurement.
At the flush point the display would not be impacted.
I think the Samsung hole(s) look kind of cool actually. Hate the notch look. How anyone can even compare the two is beyond me.
Tolerable yes.... Cool not so much. Everyone is different as far as what they like or tolerate. I don't find either one a problem comparing them side by side. At first when I saw the double hole in leaks I was like "Oh No"
Exactly....all this fuss about notches and holes doesn't amount to much. In the we should all buy what makes us happy. Notches and holes aren't deal breakers for me. As for which is better.... That's up to individual preference.
Certain apps, mostly games in landscape use the entire screen. This may or may not impact anything.
I much prefer the hole punch, over that ugly notch in the center.
Almost anything is better than a fugly *** notch. Even this hole punch thingy!!
sure the notch is in the screen. There's screen around it.
If it weren't in the screen, then it woudn't be a "notch".
Fair enough. Since it was at the top of the screen, I didn't think of it as part of it.
If the notches didn't come at the expense of valuable features, then maybe
I finally got a chance to see an S10 plus at the store I'm still not crazy about the cutout but I do think I'll get used to it and the screen really is amazing
I haven't lost anything valuable. You have to go with what works for you.
Iris scanner is removed as is the led notification. And, unfortunately, Samsung is the only thing that works for me...
i have no clue how people are saying this is worse than a notch?
The notch is in the screen takes away from way more of the screen than the hole punch does.
Yet I still have quite a bit of screen with the notch. I also have an iris scanner and notification led...
I end up with a little less screen space and more functionality.
