[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
johnh02
237
5
Re: [ROM]COLD AS ICE-CM9 Sprint LS670 11/20 ZVD basesband Alpha19
Everything's running super smooth and everything's working great. I also love the webos recent window style, thanks for adding the option to change it. Thanks kraven :)
Zakman
492
185
kraven, can we expect Native tethering fixed in the future? just wondering...
upconvert
486
3
He is rapidly running out of things to fix...
Great rom, kraven!
gingerc76
107
Well I'm sticking to the 18c build since i never had issues with it :thumbup:
Sent from my LG-LS670 oh hush
relooreloo
18
Dig the updates, and would love a whitescreen-free Gmail app, but I have to stick with 18c. 19e is giving me the same problems as Oxygen - FCs on ES File Explorer & Tweetdeck, and a glitch in Words With Friends that makes it unplayable. (I also got frequent whitescreens in Dolphin Browser on Oxygen, but didn't try the new CAI long enough to see if this problem carried over, as well.)
Not complaining, just reporting - much thanks, The Kraven, for sharing your awesome work!
Sent from my LG-LS670 using Android Central Forums
thewraith420
1,987
223
63
Hmm I will have to verify but es file explorer worked fine for me on 19a and c? Perhaps the white screen fix broke it?
Tapatalk'n it from my Cold As Ice VM670 running LS670ZVJ firmware
Seditec
146
5
18
es file explore works fine on all 19 for me
Sent from my LS670
thewraith420
1,987
223
63
Sent from my LS670
Yes, I ment I'm pretty sure it worked on one of the test versions of 19 as well.
upconvert
486
3
I think I might have messed something up. I am getting out of memory errors. I have an ov. I did a full wipe including data and sd-ext. I flashed the rom, gapps and virgin patch 19. I tried to restore my apps through titanium (which worked fine on the previous builds), but I ran out of memory. I rewiped and reflashed. I tried installing my apps though the play store, but I ran out of room again. Under settings, partition info it says I'm using 259 mb on my sd-ext, but when I go there in root browser, there is nothing there.
bluefalcon13
121
I think my nub-ness is showing.... I seem to be failing to setup app2SD properly. so far, I have re-partitioned my SDcard to hold 1Gig for /sd-ext, setup the settings under performance (to a2sd), but my apps are not dumping into sd-ext, but only into the internal flash :/
Does anyone know where I am going wrong here?
Thanks
DoesItMatter
294
37
Did a fresh install of Alpha 19E
Did a format boot, then wipe system/data/cache a couple of times
The dalvik-cache -> cache seems to be broken?
_alexkta
289
So I flashed this coming from bobzhome's ics rom and I don't think apps2sd is not working for me because my internal memory is almost running out and on my previous rom I had like 100 apps and my internal memory would only have like 15 mbs taken up, idk if I did something wrong and does anyone else seem to have this problem?
Zakman
492
185
Thanks
Same thing happened to me, I just switched a2sd to dc2sd and that fixed it for me.
bluefalcon13
121
Just tried that, but I ended up out of memory again after installing a few apps. Going to roll back to my A18 install until this evening to try and get it working tonight.
upconvert
486
3
Me too, I tried it with and without the mountext script.
DoesItMatter
294
37
On a side note - I went back to Alpha 18 (can't remember which version of 18 I am using - I think 18C)
Flashed the test35 kernel built on 11/20 - wow - that kernel is damn speedy!
bluefalcon13
121
got it working with a fresh flash:
1) uninstall anything in the downloads tab
2) set app2sd to dc2sd (assuming you have the partition built right)
3) reboot phone
4) install away!
_alexkta
289
This rom has the best battery life, thanks Kraven!
gingerc76
107
I had that exact problem, out of memory when i tried flashing 19 but I'm on the s not the v. I decided to just stay with the 18c build.
AmeliaRodriguez
