[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Zakman
492
185
Re: [ROM]COLD AS ICE-CM9 Sprint LS670 11/20 ZVD basesband Alpha19
Well I'm also running bobzhome's kernel. With my custom build. White screen fixes seem to be working.
_alexkta
289
The volume doesn't seem to work, it only stays at loud it doesn't lower with the headphones or without them
Never mind I rebooted and that stopped
Encerspay45
619
32
So, on the new update, does this mean I can disable apps2ext?
koeylondon
226
Just so we're clear, TheKraven, I'm gonna miss this rom starting Saturday when I get my new phone.
You're like that online friend I don't really see, but who's constantly sending me awesome stuff. I will miss you, and this ROM, more than you can know.
Thanks again, and I look forward to another build before I leave. ;-)
koeylondon
226
Actually, from what I can tell, all 2EXT scripts are now disabled by default.
gyanos422
11
I tried to flash this on my VM670 but get Status 7 error. how do i install on this device?
thewraith420
1,987
223
63
What recovery are you using?
He got it... He was on cwm green and switched to xionia. That did the trick
Tapatalk'n it from my Cold As Ice VM670 running LS670ZVJ firmware
Thraeryn
DEVASTATOR
Mar 19, 2011
256
33
Should be in Settings -> Advanced Settings or something along those lines.
Thraeryn
DEVASTATOR
Mar 19, 2011
256
33
got it working with a fresh flash:
1) uninstall anything in the downloads tab
2) set app2sd to dc2sd (assuming you have the partition built right)
3) reboot phone
4) install away!
This finally worked for me. Make sure you switch on the app2sd extension of your choice, make doubly sure you have not downloaded/updated any apps that show up in the "Downloaded" tab of your "Settings -> Apps" page, and reboot. Play Store and TiBu are installing to /sd-ext as directed now. :D
Edit: Batch backup on TiBu seems to have installed everything to internal memory instead of /sd-ext. At least, that's what the phone thinks. Getting different info from the a2sd info in Performance. I'm not really sure what's up, but for now, I don't recommend batch restore.
Gotta test out Bluetooth, see if it still has the "reboot phone when Bluetooth is turned off" bug.
ES File Explorer is also FCing for me on 19E.
Encerspay45
619
32
Ugh.
I just love this ROM so much, from the FastCharging to the overall smoothness and stability, it's pretty great.
The only complaint I have is that I can't get Link2SD working!!
AHHH!
thewraith420
1,987
223
63
@kraven es file explorer works fine in 19testd I just double checked
bluefalcon13
121
So far 19 is great. It does seem to have too deep sleep issues (atleast on wifi) as it kept pausing my play music downloads after the screen was asleep for 5-10 mins. Plugging it in and setting phone never sleeps while charging resolved this issue. I am assuming its sleeping too deep just based on symtoms alone.
I havent noticed any clock lag yet, on the newest kernel that is.
Sent from my GT-P7310 using Android Central Forums
justinedwards
