[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 3/20 ZVD basesband Alp
I tried booting into recovery and wiping cache and than rebooted and that solved nothing. Lemme try dalvik
I'm back in the CM7 due to battery life in CM9.
So here is what Settings - Storage shows:
Total Space 165MB Available Space 24.72MB
SD Card Total 29.71GB Available Space 2.27GB
In Titanium Backup:
System ROM 166MB (40.5MB free)
Internal 172MB (25.9MB free)
SD Card 31.9GB (2.43GB free)
Obviously, this does not make sense comparing the two. There is a missing factor somewhere.
It seems that the Settings reads ROM Total and Internal Free space (?).
whats wrong with battery life. I been on my battery for 26 hours
I tdrops to 40% in ~four hours with very minimal use, and 5.5 hours it turns off. I charged fully, unplugged at bedtime, 7 hours later it dropped to 65%, no use. :confused:
Messing with a ton of battery/data control apps, Juice Defender, Wireless Data Chief, SetCPU, NoFrills CPU control, AutomateIT, ad nauseum..... ;) I own them all, but one thing or the other does not work / annoys me, so I try another. I'm probably making it worse by tinkering. :D
I noticed not overclocking helps a LOT for battery life. Even up to just 729mhz will make it pretty bad. Stock speed isn't terrible after all.
When I was testing out Alpha 5, the battery life was terrible. I think it was due to the app multi-tasking, since I'd find my data intensive apps still open in the background or something. Just my 2 cents here. I probably won't go back to CM9 until it hits beta because even with an extended battery, my phone wouldn't last too long on CM9.
this is what i do. recharge the battery fully the reboot the phone and pull out the power cord
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 3/25 ZVD basesband Alp
Downloading a7 now
I have it at 600/245 with ondemand.
Alpha 5 v 12 was great for me, alpha 6 not so much in battery, awesome in everything else.
I'll try that, interesting idea.
Downloading a7 now
Oh crap, square one here I come. :D
Be nice to have notifications in Goo Inside.
was the dithering fix supposed to cure the color banding?
So Kraven, any thoughts on adding updating through Goo.im? Could be rather awesome to be able to update the ROM through an app on the device instead of downloading the new ROM and then putting it on the SD Card :)
Early results, loves, loves, loves my wifi router, even when I tell it not to - turn wifi off, bing, back on and connected before I can reboot.
Does NOT want to connect data. Data toggles and airplane mode toggles w-i-l-l n-o-t s-t-i-c-k, even with immediate boot. Treating me like A1-A5 before V12.
Reset / wipe / format / systemFormatALL.zip. Just A7 and Gapps. @#$%&!*......
Ok, after toggling airplane, fast reboot, untoggle airplane, fast reboot, toggle data, fast reboot, untoggle data, fast reboot, toggle airplane on (symbol shows in status bar -FIRST TIME!) and off, toggle data on and off. At last! 3G in happy Cyan. ;)
Do a6 and/or a7 require/work better after flashing a boot.img? If so, which one?
Thanks!
It gets stuck on lg splash sometimes. It randomly freezes sometimes and won't unfreeze and I have to pull the battery then it gets stuck again and few battery pulls will fix it
Sounds like you did not wipe / factory reset / format everything. Maybe try again?
First boot is long, but the rest are fast, and no freezes so far. I have not installed any user apps at all yet.
I do everything twice.
My phone froze on me as well. I wiped everything and flashed debugzip. But overall this rom is kicking butt and taking names.
OMG I have not been checking AC for cm9 updates and I'm on alpha 4 while everyone's on alpha 7 I missed out on 3 alphas lol
Sent from futuristic optimus s
I have been busy with school but I am downloading A7 and the latest Gapps now. Will test and report back. Thekraven, thanks for turning on the tethering app. Your the man.
xembdttxllink
