Anyone who has one having issue with the phone connecting call fowarding mode? It worked once but sometime it seems to take forever and in some cases won't connect
Just set up Gear with Google Voice and changed my mobile voicemail to Voice as well. Now, call forwarding works fine and if I don't answer the S after a call is forwarded, the caller can leave a voicemail that shows up on the Gear and my Note 4. Wheww! I think that will content me for a while! LOL!!
Which part? Do you use google voice? That's the first step. All my phones are linked there and share a google voice mailbox. Also, download google voice from the play store and follow prompts to make it your Galaxy's voicemail carrier. Google will try to reconfigure your mailbox, and in my case with AT&T, it worked without a hitch. On the Google voice application---desktop---, you add your Gear S and link it. Google voice will send your Gear a confirmation code to verify that it is your phone. Once you verify, you've got everything on Google Voice. Finally, I removed my AT&T visual voicemail icon from my Note 4 dock and replaced it with Google Voice. As Google Voice users know, an added benefit is automatic transcription by Google Voice so you at least have a clue about voicemail messages. Hit me with any other questions.....I'm multitasking for a few hours!
OK...have you added the Gear S to your google voice setup? Once you do that, make sure you activate Google voicemail on the Gear. I am assuming you have setup Google voice as your voicemail carrier on your mobile. Go to Settings, applications, call,voicemail service.
