LG G4 Battery Life Thread
Which extended battery is best?
Looking for an extended battery for my G4. Which is better? ZeroLemon? Mugen? Hyperion? Or something else?
Re: Which extended battery is best?
The Mugen battery is incredible. I had one that I literally used for only two days. I'd sell it to you if you are interested. Only looking to sell because I got a phone from my work and don't need the G4 anymore.
What size and what life were you getting. Like SOT
Lg g4 battery life & performance... Is it still worth my money ?
Hi.. I'm just planning to buy a new LG G4 . I'm a heavy power user so battery life is a important concern for me .
Is it last a full with heavy to moderate use ?
I would like to hear G4 user's experience & opinions on battery life & performance
Should I go for the LG G4 ?
I also considering SAMSUNG GALAXY NOTE 4 & oppo r7 plus ...
BUT NOTE 4 found it to be bit old (2014 phone).
OPPO R7 PLUS have midrange specs & costs more than LG g4 . But it has 4100 mah battery with vook rapid charging ( 75 % in 30 minutes )
Note 4 : £ 330
Lg g4 :£ 280
R7 plus : £ 310
What u guys think ?
Should I go with lg g4 ? .. Or.....
Help me !
Re: Lg g4 battery life & performance... Is it still worth my money ?
I liked everything about the G4 except the battery life. Wouldn't recommend the G4 to a heavy power user unless you plan on using extra battery. Was getting about 4-4.5 hrs SOT from 8 am to 7 or 8 pm with screen brightness at 25%. Only time I could go 24+ hrs was when my daily SOT was 2 hrs or less and I didn't watch many videos.
I've observed my wife's usage of her G4 for the last few months. She typically gets on it around 8am, and by around 10-11pm, she is down to roughly 20%. She is a moderate to heavy user, using it alot for messaging, emailing, taking pictures (and some video) and posting on Facebook, Instagram, and Twitter. She occasionally browses and does a Periscope every now and then. Because the phone can do quick charging, you can be able to top it off as needed, provided you have a good charger of course. You can also swap out batteries if you wanted, and of course you can change the back cover if you're going caseless.
The Galaxy Note 4 is a solid phone, but the G4 has better specs and camera. The Oppo should have better battery life, but it has mid-range specs, and not as good a camera as the G4. I'd pick the G4 over the other two. Hope this helps!
The G4 is actually perfect for a true power user because you can charge up from 0 to 100 in a matter of seconds by simply swapping batteries.
That's pretty much what I said, but not everyone will have a 2nd battery.
Thanks for the reply dude ..
What about performance ?
Any heating issues ?
Software experience ? . I think it's far better than note 4 old iteration of touchwiz
Thanks for the reply brother .. It's helped a lot ..
Any oppo r7 plus users out there ?
Is it any good ?
It's is amazing how they packed 4100 battery in a thin design
Performance is really good. Not the fastest flagship, but it's still very snappy with minimal lag.
Never had any heating issues.
Software experience is pretty good. I never used most of the extra features and prefer stock, but LG definitely improved the UI and I think it's better than older Touchwiz.
Battery life isnt the best but can be manageable. Performance is good i have not experienced any lag. Camera is amazing very high quality. I am happy with my G4. If you get a spare battery you will be fine or buy a powerbank and your good to go for 5 battery cycles
Performance is solid. It's not the fastest or best performing, but it's very good. If you're going to buy the G4, it's probably because you need a great camera, a great screen, removable battery, or an SD card slot. Not because you need the fastest phone on the market. All that said, it's a 2015 flagship and certainly fast enough. Just install Nova launcher and performance will be a non issue.
Like others have said, battery life isn't the best, but it's offset by being removable. If you don't mind adding some extra bulk, you can buy larger aftermarket batteries so it'll last longer on a charge.
It also charges pretty fast on the OEM charger. It does seem LG was too aggressive in my view on controlling temps, as charging slows quite a bit while using it. I have a QC2.0 certified charger as well, which charges a little faster than the OEM with the screen off, but the phone doesn't fully utilize it with the screen on. Again, it's due to LG's programming in my opinion. It seems to kill charge rates at about 94°F, and QC2.0 easily pushes it higher than that, causing the phone to throttle it. Unless you plan to turn the screen off when charging, I actually wouldn't suggest a QC2.0 charger for this phone.
How does nova launcher help?
Lassi876
