Note 10+ N975U carrier universal and unlocked models firmware.
Thanks Ruben and Mustang7757! I'll check out the downloads and any further requests will be in the S20 forums.
Stay safe!
Quick question. Could me using adguard be stopping my updates from coming in? at one point I was having issues with my n9 data not working and Att told me to get rid of adguard. By this point I had stopped checking for updates and was just going the ODIN way so I don't know if the updates would have start going with adguard gone.
I'm just up at 12 am trying to figure out what my issue could be.lol
Lol...yes it could
Thanks Ruben! One thing I noticed after downloading this file is there isn't a HOME_CSC file as to not wipe my data and start from scratch. Any ideas?
And for reference I'm running the last build you posted on March 17th that you said would work for all USA carriers. All went well and AT&T added the necessary bloatware as I had my SIM installed during the install. I just want to get on the correct update schedule with this new firmware. Thanks again.
So should I just add the included CSC file and start from scratch? Not the end of the world but it would be great if there's a workaround.
Yes you have to put the CSC , so make sure you make a backup cause it will wipe your data.
Sarah83
