Note 10+ N975U carrier universal and unlocked models firmware.
Should I flash this TC9 on top of the BT6 or do I need to flash the C2 firmware from ATT first then flash this one?
You can do it , you don't need C2, all you do so your data doesn't wipe put all the tar files in the slots it goes in and on slot CSC put HOME_CSC instead of CSC that way it will upgrade your firmware to TC9 with no data wipe , and also make sure you don't use USER_DATA. Last slot stays empty.
Man, thanks... You're awesome with quickly replying to my questions. I don't always keep my ATT sim in my Note so I never get the software updates OTA.
Np i do this every month lol with new firmwares.
Awesome because I'll be looking for them every month now that I know you're a reliable trustworthy source. I used your update last month so getting ready to flash this one now. Thanks again.
I don't know if Ruben can get that one for you
If he's willing to flash N970USQU3CTC9 on AT&T Which Verizon and Sprint released OneUI 2.1, I Can get it Just remember AT&T most likely throw a higher April patch OneUI 2.1 , So up to him if he wants to flash i can get it.
EDT: This means if once AT&T rolls out there OTA April Patch you won't receive it unless AT&T decides to go with the above firmware then you will get OTA for May patch, but if it's a Different April Patch firmware they throw no OTA till i get the AT&T April Patch.
Many thanks to both of you for the help, explanation, and offer to get the patch! I'll just wait for AT&T to release their OTA patch since it might be a later version.
Ok np , to be honest your not missing much with 2.1, So Waiting Is Good as well, but once AT&T rolls there's out i will be getting it and link it here once Odin files are available from where i get it,
SM-N975USQU3CTC9_Spr...does the Spr stand for Sprint? I have an Att phone...can I use this to update? Thanks man!
You can , sprint is (spr) if att rolls out a different build number later you just need to flash to that
So to use this Sprint update on my Att phone, I just flash all the tar files as usual, use the home csc and skip the user data?
Tiokujha
