[ROM] Android Open Kang Project- Jelly Bean Style
Some led control thing. Can't find much else.
Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
I downloaded some HTML file from that link (release 6), was it suppose to be in HTML?
TapAtalK Sent!
TapAtalK Sent!
No. It must be downloaded on a computer lol
Well, I renamed the file extension name from .HTML to .zip and was able to flash it. Not seeing much of an update.
This is new but not working and the led section is there as well.
TapAtalK Sent!
Ok so I followed the instructions all is loaded. I hate downloading the apps, thankfull I have NOVA. I was going through some of the apps I use, I tried the GPS, I get no audio, I went into
Text-to Speech Output and tapped listen to an example, nothing. Known issue with AOKP? or like in Jakes JB there was a file to install for this to work?
Also in the pull down toggle what is the "pink icon"?
And when I do a about phone AOKP version shows aokp_toro_jb1, but I downloaded 4 from the link on page 1.
EDIT: OK same issue as with JB missing file - Found answer on RW: Worked for me!
Fix for the Text To Speech issue
Put a copy of libpatts_engine_jni_api.so in your System/Lib folder.
I grabbed that file from the 2.6 ROM. Here is a link to it in my drop box: https://dl.dropbox.c...gine_jni_api.so
Credit to Scripting Samurai fpr posting and Vek_ in IRC for discovering the missing file.
Thanks,
Xanth
So what's up with the version showing build 1 in about phone? Just clean flashed preview 6 but aokp version still says aokp toro jb build 1
Oh yeah and restore not happening with 726 gapps :(
It seems that everyone will say something different, but I'm having good luck with the latest gapps from goo.im (7-26 signed gapps).
Is it OK to dirty flash aokp like we were doing with Jakes jb ROMs? I am currently on p4 with Franco 225.
Anybody rocking the Trinity 1344/384 Pre35? I just did a clean flash with Preview 6, and immediately flashed Trinity on it to see if it improves battery life. In hindsight, 307 would probably be wiser if I'm looking to save battery... but I wanted the hotter gpu for that buttery smoothness.
I've been dirty flashing since preview 1. No issues here
A nOte sent from my Kanged smartPhone via tapatalk 2
The stock kernel shouldn't be dismissed that easy. It works really well, and I got awesome battery life on it. Like 22 hours with 2 hr 20 min on screen time.
Im currently testing the trinity stable releases, 307/1344 is really nice so far, just as it was in experimental stages. Probably will switch over to the 384 or 537 slot build after the weekend.
Reactions: JkdJedi
Its hit and miss with gaaps right now, like Russian Roulette. If you have Titanium then that shouldn't be that much of a bother, I actually prefer restoring apps with titanium because Google will almost always load every single app you ever downloaded to your phone, with Titanium you pick and choose which apps you want, proper.
TapAtalK Sent!
What was your brightness settings at that time?
theantithesis
