[ROM] Android Open Kang Project- Jelly Bean Style
Nice catch Jkd! Any change log for 7 up yet? or anything obvious to report after flashing?
Ill have a mirror for this build in 15 min for anyone experiencing slow downloads....
reb0oting as we speak, I'll update in 5 mns.. (oh, no change log it was leaked in the thread, not in OP)
!!!!!!!!!!!!!!THEME MANAGER INCLUDED!!!!!!!!
Can you report if track switching with the volume keys has been added? I know, strange request, but i used it all the time on AOKP MS5.
No POWER controls yet, I didn't see or notice anything else added besides the Theme MAnager.
Reactions: kca2000
Am I missing something...? Flashed AOKP P6...
Where are all the customizations? Settings... I have only Two New options:
Rom Control
Device Options
Rom Controls:
only a misc setting under General UI
LED Options:
seems to be all there
Clock:
ok
Toggles:
ok I guess - what is Swagger?
Battery:
alright
Nav Bar:
Only three icons?, I thought we can put 5
What the heck is Device Options...?
what do we do here?
Where are the AOKP Options
Like getting rid of Verizon Wireless?
Everything seems to be working, did I flash the wrong ROM?
Thanks... totally new to AOKP...
on the upside... good to see the ICS clear search bar back and having the option between the JB one...
Rom Control
Device Options
Rom Controls:
LED Options:
Clock:
ok
Toggles:
Battery:
alright
Nav Bar:
what do we do here?
These builds are preview builds for AOKP Jellybean. All the options from AOKP ICS have not been implemented yet. Remember, it took months for AOKP to become what it was in Milestone 6, It will be the same way with Jelly bean now. This stuff does not happen overnight. As the builds keep coming, so will additional features.
for some reason my Google Music isn't even syncing...
Gallery also...
I couldn't restore from TiBu... but the only thing that pulled up is
Browser
Calendar
Contact
Gmail
is this normal...?
I don't know... if I can't restore TiBu, and I have limited syncing... I just might go back to Jelly Belly before the weekend is up...
Gallery also...
Browser
Calendar
Contact
Gmail
is this normal...?
Did you flash the GAPPS file after flashing the ROM? Did you wipe everything before installing? Most things should work straight away.
I thought I did...
let's see:
gapps-jb-20120726-signed
oh, yeah, I have Gmail, but nothing else, no G+, Maps... should I try to flash gaaps again?
I thought I did...
let's see:
Thats the right file.
Pretty sure GAPPS dont include those but i could be wrong. Never flashed without flashing GAPPS.
If your not to far into the install download P7 from the previous page and use the same GAPPS.
Follow the directions below.
Skip the nandroid if you already did one.
Download the relevant zip(s) and place them on your phone's SDcard.
Reboot into Recovery--CWM or TWRP.
Wipe CACHE AND DALVIK CACHE.
Create a BACKUP/NANDROID of your current rom.
Wipe the phone completely--data, cache, dalvik, and system.
Install/flash the zips. If there are more than one, make sure you know in which order to flash them. Install the ROM then the GAPPS
Reboot your device and be patient.
Wait for a minute or two when you get to the "Welcome" screen.
i did get TiBu to work... somehow, when I flashed, the TiBu folder when blank...
glad I make a copy to drop box, cause the folder that copied to the local drive was also blank or had one file...
so I am able to recover most apps, but still Gallery and Music, can't sync...
getting late again...
I guess I will try to go back and flash Gaaps again, tomorrow...
How can I access the parent folder with my PC, when I connect it to the usb cable, all I get to see is what is on the sd card.
but if I use rom tool box I get to see everything.
Is there a way to access from the pc?
Thanks!
unhappy74
