Was the kernel updated, if so can i get the link? From what ive read its 0614
I think what happens is flashing roms likes to mess with the battery charge and how well it holds one. I think you probably need to wipe battery stats after the battery gets low then recharge it. Someone posted how to properly do it at one point
Arjen thank you for the awesome work and kernel it was a pleasure. I have decided to part with my phoenix and buy a samsung galaxy s i897 captivate which will be here Wednesday. Mainly because of its a8 cortex hummingbird 1ghz cpu and near top of the line gpu. Wich should be able to handle most things i throw at it like netflix flash crackle games and more.
Lol i guess what im saying is you are an amazing dev and acomplished what many have tried but failed some muserably. Keep up the great work and i will continue to follow your work and buy you a beer every now and then to support your cause.
Sent from my LG-P505 using Android Central Forums
if only we could all be so lucky to get a newer phone. phoenix is like the evil twin brother of of an iphone but with less power
Thanks for the tip!
I know how to do it thankfully
Messed a bit with the CPU settings and the system settings and now its draining about 7.5% an hour. Better, but still not at my standard![]()
How could you Arjen??? An iPad?Sent from my iPad using Tapatalk HD
I send files between my Thrive and my HP ENVY 15 all the time so I think it's fine
How could you Arjen??? An iPad?![]()
