[ROM][CM9][ICS][4.0.4] Cyanogenmod 9, Android ICS 4.0.4
Which is more stable with lg thrive. The p500 build or the p505 build?
I haven't done a randomized controlled trial, but you should just use the p505 build so that you won't have to flash another kernel on top of that. I suspect they run similarly
LG Thrive limping along with custom CM9 4.0.4
I dont know if its the new rom or what he did with the new p505 6/28 build but the battery performance is incredible. I usually get home from a long day of work with about 30%battery left using the old p500 rom that was stable for us, but i just checked my battery statistics since I unplugged it this morning at 100% with the new rom and its reading, 8h 40s on battery, and still 83% battery life left. I'm pleasantly suprised. :) thanks arjen.
which phone did u use?? p506 or p505?? just install the rom without kernel?
I would like some explanation as well. What "touchscreen fix" was implemented? Was it supposed to fix multitouch? Does it fix CPU spike when touching the screen? I don't understand. The major touchscreen bug that makes most games unplayable is still there.
Example of the bug here :Lg optimus one p500 touchscreen problem - YouTube
download the "multitouch app" and test for yourself.
I've also seen many people that have fixed this issue.
Example : LG P500 with CM7 and TA Kernel - Multitouch Fix - YouTube
I realize they are p500 in the videos but we have the exact same bug, at least on the lg thrive.
I have flashed the rom, no more need to flash the old blackscreen kernel first to get wifi working. Just flash the 6-28 rom with the 6-14 kernel then gapps.
Are you kidding me. I said it wasn't implemented yet! He made a mistake. And furthermore, I said multitouch.... Please read everything before posting. Sorry to be harsh.
Sent from my LG-p505 using Tapatalk 2
CHANGE LOG
(STABLE 4 (TINYLIGHT)
"You will have 13MB free space on system after installed rom+gapps"
26 Jun 2012
Fix volume in speakerphone mode
Remove unsupported mtp & ptp functions (no need to delete any driver anymore)
Add smartass2 governor and use it as default
Latest updates from v20D-INDIA (sensors & backlight)
Move CMWallpapers(7MB) to extras
Trebuchet changes:
- Reduced to 4MB, removed color banded wallwapers
- Infinite/Loop homescreen scrolling
- Defaults: Turn off search bar, resize any widgets, don't join with widgets)
These are the changes pretty much, from hephappys post on xda.
Are you kidding me? Keep the posts on topic in the correct threads and these problems won't happen. Or instead of relaying half-assed information from arjen just let him do his thing and let him post when its done and put a changelog. You are just causing confusion.
And if 6/28 isn't a new p505 build that he uploaded it then he must have uploaded it from the past and labeled it wrong, otherwise Id call that "new".
You really need to not disrespect members just because you have a direct line to speak to arjen, and you need to do a much better job of relaying the information if thats what you are going to be doing. Keep the ROM information in this thread, and keep the kernle information in the other thread. When arjen releases a new build it does not help to spam every thread saying theres something new. It's getting very annoying.
You don't post anything at all in this rom related thread for 2 weeks, then all of a sudden yesterday you post this:
______________________________
Newest cm9 online with latest fixes!
Sent from my LG-P500 using Tapatalk 2
__________________________________
So please tell me all about how you've been explaining things so well for people and how theres no new rom.
But then all of a sudden "ZOMG ITS NOT RELEASED YET YOU IDIOTS!!"
So please, either give more information, or just stfu and let arjen do his releases without your help.
And what does hehappy's new changelog have to do with anything? Shouldn't we be focused on the p505/506 builds here that are made by Arjen?
Not meaning to be harsh.
Reactions: electech
k, no offense, but this post was pretty harsh, im pretty sure Oathkeeper1212 didnt mean anything he posted in a harsh offensive way, the way u replied was just a complete exaggeration of what he said, dont get angry at me im just trying keep the peace
Well I didn't mean to sound harsh, but the reply he gave to me was uncalled for and I'm getting tired of information being posted in the wrong threads here. I read that Oath said there would be a new kernel yesterday, where is it? It's probably not done yet and its probably the reason Arjen doesn't come here posting release dates. Oath has a direct line of information to arjen so he knows whats going on. All we have to go on is what oath tells us. It just isn't being explained clearly as to what is going to be fixed. There is also a 6/28 rom build on arjen's pilson that has yet to be explained. Our phones aren't under Arjen's BBQLog.
Part of the confusion comes from simple things like, Arjen calling it a touchscreen fix. Oathkeeper calls it a multitouch fix. Since there are many issues with the phones, it can be read to sound like 2 different things.
Haha, nice comeback. Yeah well I'm just bringing what I've heard from him, here. you can't expect me to know a changelog because I don't worry about those things. The changelog I posted is the changes in the 6/28 rom. K?
Just wondering Arjen, do you intend on making a Jelly Bean ROM and kernel for us too?
It would be amazing :)
Tested new cm9 p505 rom and its actually performing really well at all ends. Unfortunately my SD card keeps randomly unmounting. This doesn't happen on stock so I'm lead to assume that its the cm9 build
I'm using lg thrive
Sent from my LG-p505 using Android Central Forums
New rom up, it's a test build but working flawlessly. Check pilson and it's In the p505 folder. It's a port of iScreamDX, an optimized version of cm9.
P.S. It's under the name of isdxtest. zip
Reactions: korrectmethod
Why thanks OathKeeper. I don't know what we'd do without _Arjen_ and YOU. (don't listen to other people) :p
I don't really get the significance... it seems the same as his previous version.
Yes that's what I said as well but it's just a few tweaks. It's still in alpha and he will add a lot more tweaks to it.
miyonfaga
