[ROM][CM9][ICS][4.0.4] Cyanogenmod 9, Android ICS 4.0.4
Not to be a noon or anything (I just registered to these forums) but where are the links to the toms and kernels
Sent from my LG-P506 using Android Central Forums
First page of this forum. GAPPS and rom download links are there. Go with p505 build and OBBfix (have to look for this one) since you're on lg thrive.
Sent from my LG-p505 using Android Central Forums
here is a link to the baseband fix for thrive.
http://forums.androidcentral.com/t-...mod-9-android-ics-4-0-4-a-12.html#post1833777
Also, has anybody noticed wierd keyboard issues with the 6/28 build? The haptic feedback seems to cut in and out while typing and sometimes rarely the keyboard will just randomly dissappear while i'm typing or not show up at all when i select a text field.
Yes it happens, you should try using SwiftKey 3, best keyboard on the market.
Sent from my LG-p505 using Tapatalk 2
Reactions: korrectmethod
I'll give it a shot. Also I can report, at least for me,with the new isdx p505 build, overclocking seems to be working much better on the thrive. with the smartassv2 governor 320min/768max i'm not experiencing any screen tearing or graphics glitches. :) Although CPU still spikes to 100% just by touching the screen. (normal?) Also, the lockscreen has some strange build information in the bottom of the screen.
Yeah, Arjen never really looked into the source code, he's gonna ask the main dev later.
Thanks. I will download the files today but i will install later today.
Sent from my LG-P500 using Android Central Forums
Well that could be partially true, because on my thrive, since I changed to Arjen's kernel, I haven't had any visual artifacts or something like that, so I think, that has little to do with the rom you have on your device...
That's what I think...
I can say for fact with arjens original kernel and rom i couldnt oc above 600 without major issues. the fact that ive been oc to 768 without even a hiccup now with isdx build definitely says something. The only thing I can think that I've done different is installed chainfire 3d.
I went from 81% battery to 41% in matter of 9hrs so I'm not sure how your battery's improved while mine hasn't this was during the time I was sleeping
Same here, But overclocking is stable, ta least for me
My battery was vastly improved using the 6/28 rom and the 6/14 kernel. I'm only speaking about overclocking performance with the new isdx rom. I'll admit the battery isn't as good on isdx but games run much better with the stable overclocking. The main issue with the battery is that every time we touch our screen, the cpu spikes to 100%. My battery drops about only 15-25% over night while sleeping for about 8 hours though. I'm not using live wallpaper if that could be it.
I can say for a fact on Thrive, oc to 768 max on Isdx causes my phone to constant reboot...
Try installing chainfire 3d, and under perofrmance->memory management->zram, change it to 10%. also enable kernel samepage merging. you are using the smartassv2 governor correct? I just got done playing dead space for 30+ minutes at 768 with no problems.
maybe so I flashed the rom then the kernel from 19th and then old baseband should i of flashed rom then old baseband?
shahg
