[ROM][CM9][ICS][4.0.4] Cyanogenmod 9, Android ICS 4.0.4
Aw man. I had the same issue. It just sits there with the LG Logo right?
And then the battery gets hot and etc...
Here is how to do it:
***These commands probably aren't right. I forgot the exact commands but there should be a help command :P...***
Get a recovery.img (tell me if you need one, I've got one)
Place the recovery.img in the same directory as the fastboot.exe.
Boot into fastboot and connect to your PC and initiate fastboot.
Use the command -erase recovery.img.
Use -flash recovery.img and it should do it.
Now you have CWM Recovery back in place. Just flash a ROM from there!
Thanks man, just note that for flash recovery.img you need to specify the location to, like C:\recovery.img
Sent from my LG-p505 using Tapatalk 2
When I bricked my thrive, I follow that method, It works....
If you can't push the recovery.img to your phone, because it shows an error, the only thing you could do is to erase all your data, and try that way... Erasing my data was the only way to make the comand promt, push the recovery.img
Best of luck with your phone :)
guys i am so confused right now. I appreciate the guides but i dont know which one to do ad to me they all sound complicated. If someone can simplify that would be great..
hey oathkeeper, can you help me out, i read over what rashed posted but i dont know where to get the programs he mentioned. i also need direct instrucions! Please help:(
How To: Install ADB and Fastboot on your Windows computer for use with your Android phone | dotTech
Follow this. Once installed boot your phone into fastboot mode (You already know how, or else Power+Home)
Download a recovery. put it in your C:\ Directory.
open cmd.
type fastboot devices. MAke sure your device is listed.
Then type as follows:
fastboot erase recovery
fastboot flash recovery C:\recovery.img
fastboot reboot
then hold Power+vol up+home. Should start recovery. then flash a rom.
open cmd.
may i flash a backup i made just in case something happened (aka this). that way i can just jump back into the phone
open cmd.
What do you mean download a recovery (i put that on C-drive like the ADB and Flashboot right). When do i connect my phone into the computer? Open cmd is command prompt? Please reply!
@TheLockness
DId you get your problem resolved or is it still there?
Still here my friend. I installed the abd fastboot thing but i dont know what you mean by download a recovery. WHich recovery should i download? I am just confused and stressing out because this is my main phone and it is bricked.
I was the same way when mine did it.
Send me a PM with your email address and I'll send you a recovery.img
one of these. The 3100 Allows the flash of any rom, p500, p505, or p506. the Utkanos only flashes roms designed for p505/p506.
http://forums.androidcentral.com/attachment.php?attachmentid=29398&stc=1&d=1341279245
So the flash comand prompt line would look as follows:
"fastboot flash recovery c:\recovery-3100.img "
OR
"fastboot flash recovery c:\recovery-Utkanos.img"
(I believe it's c:\, It's been awhile since I used a windows machine.)
You plug the phone in when It's in fastboot mode. And it must say "fastboot: processing commands" once plugged into the computer.
Now Arjen, The rom/kernel still contains the battery boot bug. The way I fix it in my custom roms is replace the ramdisk with that of the lgp505icskernel-14062012 kernel and it no longer contains the bootbug, however that makes it not connect to my wifi, idk why. Just a point in the direction of where it is.
Reactions: Rashed1997
OR
it wont let me unzip to C: Drive
bassey
