[ROM][JB][WIP] CyanogenMod 10 for LG-P505/506
Unfortunately I get random reboots using the 7/24 p506 build, often when just sitting idle for a second on the main screen (stock launcher problem i assumed). I flashed the jb-gapps and Google Now still FC's trying to open it. Keep up the good work.
Is Google Now really the only advantage to getting Jelly Bean?
Sent from my LG-p505 using Android Central Forums
I think is is actually supposed to be faster and more responsive than previous versions
OK I'm back :)
The 7/24 build did mess up the sound, I'm building a new one right now that SHOULD fix the sound
As for those issues you mentioned, thushanth, I'm working on those as well. The camera doesn't work on most CM10 ROMs right now and battery drain is certainly an issue as well. If you want those things I sugest you using the stable ICS ROMs by Arjen found here: http://forums.androidcentral.com/t-...cm9-ics-4-0-4-cyanogenmod-9-android-ics-4-0-4
Random reboots are an issue as well for me. I get them all the time :P
Google Now is one advantage of Jelly Bean. The others include much smoother and faster, much more responsive, and security issues have been addressed
Reactions: thushanth
Any ETA on the next 505 build?
Depends on how soon I can fix these darned issues for my P506 build
CM team screwed up the entire display system and I'm stuck fixing it to attempt to compile...
If this fix works I'll upload to GitHub and hopefully Oathkeeper can build P505 tonight
If the camera works this build, I'm making an entire family build :p
P500, P505, and P506
That's IF it works :p
I'll hope for the best.
Sent from my Amazon Kindle Fire using Android Central Forums
Reactions: Rashed1997
Well I gave up on editing the screwed up files to make them work so I just reverted the entire repo to July 17 :p
It's only a matter of ~1 hour now :)
OK New ROM coming in a few min
LINK WILL GO HERE WHEN I GET BACK!!!!!! (going out to dinner :D )
Changes in this ROM:
-Catapult has officially replaced the stock launcher and Trebuchet (it should work)
-Updated HAL so camera SHOULD work
-Fixed button backlit lighting
-Settings, Phone, MMS, Camera, Email, Exchange, Dev Tools, KeyChain, DSP Manager, and Apollo apps have all be updated with various fixes
-Theming engine ported to CM10
-Various fixes here and there
-Repaired audio engine
-Repaired display engine
-Better support for other Jelly Bean stuff
You better be finished with dinner because I want dessert: Jelly Bean!!!:D:D:D
Sent from my LG-p505 using Tapatalk 2
Lol. Yep, I too have been awaiting this. I guess I need to get familiar with coding and development. I so want to contribute
Sent from my LG-P505 using Android Central Forums
OK back
I tested and it boot loops so I need to fix Catapult. Give me exactly 30 min
If I don't have it by then you can yell at me :P
Thank you for that. I will see what I can get my hands dirty with
Feel free to commit any thing you see that needs fixing too :)
Catapult proving hard to fix, I'm gonna revert back to the last stable build I had. Means no settings menu :( But fixed dimensions :P
I'm picking around trying to see if there is something I can do to get it to work on the phoenix :-/ my options are limited though due to me not having access to my laptop
That is beautiful news. I've been using the paranoidandroid rom and its been perfect. But this excites me more
Reactions: Oathkeeper1212
Gasho
