ARCHIVED: [ROM] Opti-ROM v1.1 built-in apps2sd, storage management, OCable!
Status
Not open for further replies.
Re: [ROM] Opti-ROM
Battery life on 1.1 is incredible. Off charge and idling was still at 100% after 4 hours
Re: [ROM] Opti-ROM
Couple of interesting things.... ;) have to wait and see. Making sure there are no issues prior to releasing, then it will be all yours guys!
Reactions: mike9670
I dont know if its my phone or an issue with the rom. But i use my wifi like 99% of the time and my wifi has stoped wokeing twice and i have to reset my phone to work
Re: [ROM] Opti-ROM
Anybody else having screen sensitivity issues?I can't even swype without unintentional letters popping up everywhere. And organizing the screen with GO launcher is a chore.
Re: [ROM] Opti-ROM
I haven't experienced this at all.
I suggest trying to flash a theme from jstntp and seeing if you still have the issue. It could be a couple of things. The IQ thing could have something to do with it, or not. But that is my suspicion.
Also, if you have WiFi enabled, try without WiFi... See if you still have the issue.
Re: [ROM] Opti-ROM
ive had this issue with all the vh roms and it seems to go away after a few reboots and or a days useage. i dont know why but it does.
Reactions: basketthis
Re: [ROM] Opti-ROM
Yep, I had reports of it on gROM and stock ROM as well. Its something in the release. Prolly another bug Sprint is not living up to yet. I also noticed that if you are overclocking while this happens it tends to intesifiy the issue. But that's jut my two cents.
Re: [ROM] Opti-ROM
Stock Theme Bug:
With the nice cool blue stock theme there is a problem when you are roaming, The roaming indicator triangle flashes on/off with black background. Can it be fixed to not flash and have the stock blue background?
O:-)
How about the LG launcher from ReBorn ROM? That was a nice launcher.
Re: [ROM] Opti-ROM
Is there something wierd with the battery meter on opti? It would sit at 100% for hours before starting to drop. After putting fancy widgets on, I would wake the phone and the meter would start flipping between 100/90% maybe showing that it really is at 90% after a few hours and hte 100% was a false reading?
Re: [ROM] Opti-ROM v1.1.1
Batter meter: Opti woudl say 100% after a few hours, switched to a different ROM and battery was a t 88%.
Your concerns are not falling on deaf ears. This may be a ZVH issue and just popped up when you flashed Opti-ROM for some reason... Try unplugging and plugging in your charger and it should show the proper value. It happened to me when I was running stock. ;)
EDIT: Also try the newest build from the first build. :)
I just wanted to give an update I was able to flash the newest ver of the rom and guess what it worked no problem I am assumeing something in kernal 05.1 fixed the issue thank you drew for all the hard work on the kernal and all you other devs thanks for the hard work on this rom. I will donate as soon as I have money.
Loading up latest gROM 1.2 for testing this week
Yeah, that is a VH build issue for sure.
Status
qpss
