metle_geek
- Jul 26, 2013
- 1,018
- 0
- 0
Trooperxxx had the solution for me, it was the cable.
"I experienced the same issues after getting the S4. The solution: You MUST use the USB cable that came with the phone. If you use another USB cable, it will charge but will not connect to a PC. Once I used the supplied cable that came with the phone, it connected, was recognized by my PC correctly and was able to access the phone files on the sd card and phone memory. My phone is from Verizon and is on Android 4.3"
Thank you for the help!
Yes and no some cables are charge some are data cables (data cables do both) if you buy a secondary cable make sure it's also a data cable and not just a charge cable
Sent from my SAMSUNG-SGH-I337 using AC Forums mobile app
