So I am coming from my Storm2. A phone I loathe except for the amazing notification system via BerryBuzz. I find it impossible to believe that this new Tbolt super high lets you customize everything but the most important things from a notification perspective.
Here is what I had on the Storm2...
1. Phone Vibrates then Rings - so I could quickly know if I got a call in a meeting and silence it before it rang.
2. A bright LED indicator light & Berry Buzz - whose color I changed for SMS, FB, EMails, and Twitter - Blue light = Facebook notification, Green=Email, Purple=SMS etc. I could look at the phone from across the room and see not only that I had a message, but what type it was. Moreover, it had two colors so I could further customize the phone so if it was Purple followed by Orange light that meant SMS from Jane Doe.
3. Custom vibrations - Long 5 sec, or short bursts. No vibration, just LED etc. Ability to have SMS vibrate with a repeat alert every 2 minutes. Ability to just have emails blink and not vibrate.
None of this seems possible with the Tbolt or even close. I've looked at Blink and will look at Handcent.
A. How can there not be Vibrate THEN Ring for calls, SMS?
B. How can you not customize the vibration lengths?
C. How can there be only two colors of the light?
D. How can they bury the light behind the mesh part? It's impossible to see in
the daylight and at various angles other than straight on.
E. How does Swype not come pre-installed? The beta doesn't seem to leave spaces between the words.
Any reco's on any of these will help.
