mrkane420
I put myn 2.2 rls 5 on my phone everything works fine except when i use the hotspot it kicks me off 4g and only works on 3g and i get perfect 4g where im at is anyone else having this issue ?
At work. I'll check it out.
I was wondering if I already have the updated radios and wimax do I need to download those add ons???
No need to. Just install the rom.
Ok thanks, and for some reason my internet is running super slow anyone have an idea why that is happening??
install adfree in the market and clear all caches. I'm almost sure that will solve the problem.
Hawaiijedi sorry for the late late response the reason I had problems was because of the flash player before it used to mess with the hack they said they fixed it but it was wakey on mine do once I took flash off and went into my settings and applications then look for hulu and you see clear cache once you click on hulu you'll see cache don't do it from the recovery and then you should have no problems again
Sent from my PC36100 using Tapatalk
Is 4G still not available with this ROM?
