Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 6/3 ZVD basesband Alph
are we able to use this rom to use the portable wifi hotspot in wpa-psk mode? i know we are supposed to use a app (barnacle or wifi tether) as a work around. i have a kindle fire that can connect the the optimus hotspot when using a gb based rom and wpa-psk. no app, just the stock wifi hotspot from the rom.
however, when i run this rom and the wifi tether or barnacle app, they seem to only use wep, so it doesn't work the same. my kindle fire (hashcode's 3.0 kernel) sees the ad-hoc hotspot, it will connect and state "optaining ip address" for a while, never connecting, and then disconnect and the process starts over.
i'm a noob, so i would appreciate any insight that you might have. is the first scenario (wpa-psk) not ad-hoc? any other workarounds for this wonderful rom?
thanks in advance
