[7.14.11][ROM] Das BAMF Sense 3.0 RC4.9
Hey guys, I haven't been around for a week so haven't exactly been keeping up with the latest developments on this rom, but have been really pleased with it on my bolt. I have been having one strange issue and think I finally nailed down the cause. Occasionally when I go to send a text message or to make a call, I'll get force closes in the phone process. The radio will reboot itself, but the message still won't send. I've tried a number of things to attempt to nail down the problem, but none has seemed to consistently fix it. Recently I did notice a trend--I run into issues when the numbers are stored in my phone book from Facebook in the format +1###-###-####. A couple of times (once with an SMS message and once with a phone call), I discovered that if I removed the +1 from the phone number (i.e. ###-###-####), it worked for me and the force closes didn't happen.
So here's my question. Is this a known issue? If so, is the issue with Bamf or something else? Secondly, is there any way I can get my Facebook contacts not to download to my phonebook in that format? I haven't been able to figure out how to do that.
Anyway, thanks in advance for your help!
I have also noticed this and wasn't crazy about how distorted the sound was do to this but I love this rom and decided to live with it for now and hope there is a fix coming.
I haven't tried this newest bamf version, but I found the last few ROM's I've flashed have poor sound quality. I just flashed gingervitis, and it seems the most acceptable.
i flashed this rom yesterday and i am impressed, but ive found something that annoys me a bit. the apps i have installed/moved to my sd card are working no problem but my "quicklaunch"? icons for them seem to lose their respective icons after restart and it stays that way until i switch out the icon for a fresh one... here is a pic for example..
http://imageshack.us/photo/my-images/269/cap201107250734.png/
the notification at the top is another small issue ive been happening but it has happened all the time in my house from time to time and happened with older phones ive had, sending pictures always yield multiple tries...
I think I have a bug that I have not seen reported. My phone shows the voice mail icon all the time. Yesterday I missed a call and it showed a i had 4 VM's. I checked and cleared all of them but still have the VM icon. If I reboot it goes away, but it should clear as soon as the VM is checked.
Installed this easier today, excellent work. Are there any themes available that would allow me to change how the battery status is shown? For example a circle with a number in the center?
just installed and im getting no service at all and my device isnt showig up on my computer now i need help fast
I've tried searching here and over on the BAMF forums with no luck.
Does anyone know if there is anyway to customize the buttons on Rosie? Or at least the one on the far right, like you could in other versions of BAMF?
Thanks in advance.
i love this rom. but wondering if i could modify a few things
is there any way to remove the battery percentage out of the battery i find my self looking at it to often.
also is there any way to make the power reboot menu stock and not have all the extra options
. thanks keep up the good work
Just wondering where this ROM went from XDA dev, I did a search and found the thread but it was closed with a message "Advertising is not permitted on XDA". I love this ROM what happened?
Lately some developers haven't been getting along with XDA. I don't know if this affected BAMF or if there are other things going on - maybe they just want to plug traffic to their own site - but I noticed it's not listed in the general ROM listing there.
You can find it here:
[GINGERBREAD] Das BAMF Sense 3.0 RC4.9
can anyone help with this problem, I really like the Duality font and had it working on my phone befor, I installed a theme that I was not happy with. So not yet having a backup with this rom I reflashed to remove the theme, cleared all data etc. But now when my phone reboots and I try to apply the font the phone locks on the splash screen. Tried to apply the font twice so far and had to reboot into recovery using adb to get my phone back up and running. Anyone have any ideas.
Also it appears that it is not just the one font any of the fonts I try to apply cause the same lockdown. I really like the font changer. All I can think is that there is something left behind on the phone even after a fresh install something is still there causing this to happen, but I cannot find it.
Anyone else had random reboots??? This morning and maybe 2 days ago my phone rebooted just sitting on my desk. With RC4 I dont remember having this "issue"
Jshiv
