[CDMA HERO ROM] Gumbo 2.1
Someone who hasn't fixxed their database, please try pushing the attached file to /system/etc/:
Code:
unzip file to SDK/tools/
adb remount
adb push apns-conf.xml /system/etc/
Then delete the DB and reboot
Code:
adb shell
cd /data/data/com*telephony/databases
rm telephony.db
reboot
then try sending an MMS
So all I have to do is flash the zip as an update zip in recovery?
I need ONE person who doesn't have MMS already fixed to:
Nandroid backup
flash the attached zip
reboot
reboot again
try to send a MMS
If you're gonna try, say something so everyone else doesn't try it. It's fixed via the script, just trying to deliver it correctly.
Nandroid backup
reboot
reboot again
try to send a MMS
I will try
excellent
everyone else hold off until beezy reports back
What it's doing -
the commnads to switch from verizon to sprint (as already posted) are put into a script, that gets called at every boot via the gumbo.sh service.
the initial flashing of the zip file will delete your original telephony.db (in case you did try to use my other xml file and it's hosed). That's why you need to reboot twice, to rebuild it. Better than wiping data :)
the question is if the gumbo service will correctly call the script, and beezy is gonna find out for us
Are you in Atlanta?
You might have issues because your network actually uses the extended WiMax code, even though your phone doesn't.
Try enabling Airplane mode, then toggling back.
Then try enabling airplane mode, then rebooting while in airplane mode.
im going to try that right now..
n no at the moment im in new jersey
EDIT: Its still not working.. i kept getting force close on 3G Update or something.
Quick thought - which zip file did you download and flash?
the test21.zip file isn't a complete ROM. I posted it up in case anyone else wanted to work on the Eris dump, but it ended up going faster than i anticipated. I left it for folks who like that geeky stuff :D
I'm just gonna get the MMS fixed then I'm off to bed. Been up for 2 days lol.
But thanks for the offer. Now cross yer fingers :D
Gbhil
I followed the steps that was posted in XDA for Flips rom for the mms fix on your rom and it work.
Is this what you are trying to zip up?
- adb shell
- cd /data/data/com*telephony/databases
- sqlite3 telephony.db
- update carriers set mmsc='http://mms.sprintpcs.com/?X-MDN=MYPHONE' where name='Production';
Excellent work as always Gbhil. As much as I love my camera, I think I can give it up for a few weeks to use this ROM until the official update comes.
What part of the 757 are you from Philosophy? Chesapeake here.
slametmunawir010796
