[CDMA HERO ROM] Gumbo 2.1
why do i have all my face book contacts on my phone list ? but when i press people its just my contacts
JIT didnt work for me.. it just locked up the phone on boot..
But I must say that GB's version on this rom is the Fastest..
does anyone else have to log in to google every time they reboot? and yes i followed the instructions on the install and did not sign in till i rebooted?
Yeah i have the same problem.. everytime i reboot it happens. its not to big of a problem tho.
Hello all,
First, I am very impressed with this rom. Good Job! Android has bright future. Everything worked great.. of course, not but one thing is my phone can't connect EvDo.. I am on roaming mode. Since, I am out of country. I assume mobile network works for you guys with Sprint, right? then can you try set roaming and see you can able get mobile network (evdo). I am stuck with Wifi, SMS worked fine and hasn't tested mms yet, because I am not able connect to mobile while roaming. I don't know about voice since my account blocked it due to sprintrelay unlimited data plans. Just thought to post this that would help you to sort out the bugs. Let me know.. Cheers! I gonna try Flipz's and see if difference and will post for this..
Got market working with protected apps after changing the fingerprint in build.prop. Here's what I'm using:
ro.build.fingerprint=google/passion/passion/mahimahi:2.1/ERD79/22607:user/release-keys
HTC Sync
Anyone able to use HTC Sync to sync with Outlook? Common solutions of reinstalling drivers, programs, and restarting are not working.
for MMS I followed these instructions and it worked PERFECTLY (Send and Receive work)
adb shell
- cd /data/data/com*telephony/databases
- sqlite3 telephony.db
- update carriers set mmsc='http://mms.sprintpcs.com/?X-MDN=MYPHONE' where name='Production';
Obviously replace myphone with your #. You can control-C out of sqlite if you're still stuck in it.
yea that would be helpful if anyone knew how to switch the keyboards out i friggin hate the htc keyboard google on is way more efficient
i flashed this rom last night and had no prob with the market and all my apps showed up and didnt do anything special to fix it....am i missing something big here?
probang
