[CDMA HERO ROM] Gumbo 2.1
confused about the process.
From what I can see,you would have to edit the build.prop. If you know how to open and sign a .zip I could walk you threw. If not just wait for GB,me or someone else makes it.... sorry if that doesn't help any.
Can you tell me the name of a app you want but can't see?
Ok I'm awake lol.
re - Facebook sync - That's the new way HTC does it. In the people app you can choose to hide all the FB crap.
re - Roaming - I have no idea. I'm at my house, where there is nothing to roam on. My gut tells me it won't work.
re - MMS - until I can find a better solution, enable it the way that was posted. The problem is that the APN isn't configured. I'll keep plugging at it, but if anyone comes across something better, let me know.
re - Stock keyboard - this is a Sense ROM. The Stock keyboard doesn't use the Sense framework. If someone wants to rebuild the Stock keyboard to work with Sense's framework, go for it. I like the Sense keyboard because I need to type a lot of alt characters so I am not worrying about it.
re - Market - The fingerprint on this ROM shows Paid apps. It also shows some protected apps. It doesn't show paid protected apps. First thing to learn is not to support developers who insist on marking their apps as protected. It doesn't stop anyone from yanking them off the phone, it doesn;t work with apps 2 SD, and it causes this same problem any time a phone is updated with new software. Same exact issue happened with the official Sprint, Eris, Droid, G1. etc etc updates. Can someone verify 100% that the passion fingerprint posted fixes the issue? Like not seeing certain apps without it, and seeing those apps with it? I can easily make a flashable zip to update the build.prop with the new fingerprint once someone can tell me 100% that it works.
Ok I'm awake lol.
I'm working on getting the latest stock keyboard (with voice input) working. It's at least asking me which keyboard I want to use now.
Twidroid was not showing in the Market until I changed the fingerprint, it is definitely showing now.
I'll keep everyone posted on this forum what I come up with on the stock kb, the spelling and over abundance of "lol" on the Hero forum @ XDA has started to make me want to gouge my eyes out.
Glad your awake!!! I'm going to try the fingerprint post,but what's the name of app that can't be seen?
Twidroid shows for me with no changes...edit..Was:eek:
Excellent. Anything you come up with about the KB will certainly go in the ROM, and you'll probably make alot of folks happy/
Try the paid version of Afirewall or Twidroid Pro
Weird, could just be intermittent.
I'm going to blame it on solar flares, personally.
Best explanation ever.
I think i have the APN figured out and have an easy flashable fix. wiping and reloading as I type to test it.
Getting SIGILLs from LatinIME when it tries to bind with Voicesearch. Between this and actual code @ work, I'm done until Monday :) I have a few ideas on how to make it work.
i flashed this rom last night and had no prob with the market and all my apps showed up and didnt do anything special to fix it....am i missing something big here?
I have Payed apps but the Protected Payed apps arent showing up .. example DroidLive (not the lite version)
the fix doesnt fix this
Give it a few after rebooting for it to show the other apps. It took a little while for me.
I tried flashing this and it hangs at the nexus boot screen. It moves for a few minutes and then locks up.
I didn't wipe so could that be the reason?
Hi guys ,anyone having problem with the browser sudden closed. After it closes ram increased. Not sure if it me or that's normal.I think the ram killer is too aggressive.
Chris 4502
