[ROM] [05.25.11] Das BAMF 1.7
Second Rule of ROM flashing... ALWAYS MAKE A NANDROID first :)
True...
Unless ROM Manager decides to **** up and sabotage your SD card and corrupt your NANDROIDS effectively ERASING them.
I lost all mine flashing over to BAMF 2.0. I even did it through CWR too.
ARGH!
No stock to go back to... unless I download it
True...
ARGH!
You can back up your nands on the cpu and reload them to the sd card.
Not that i do
sorry if i overlooked it but i didnt see this problem. when i try to turn on wifi it just says error. any help would be appreciated.
ROM manager just likes to break things when it comes to flashing ROMS. ClockworkMod is all I use, and all you need
Has anyone else tried to use the patch Disable wake on volume and it does not seem to work....?
Works fine on my phone. I've used it for the last couple of versions of das BAMF. You may want to clear cache and Dalvik before reflashing.
GermanAndroid2403
