SamsungSucks
- Feb 22, 2011
- 20
- 1
- 0
Then I would suggest changing your lower end number processor speed setting, stock setting is 100 Mhz and switch it to 200 Mhz and see if that helps. Some devices just don't react well to the 100 Mhz setting.
Either grab SetCPU from the 2nd post I think it is at the XDA thread for Syndicate or you can grab OverClock Widget from the Market.I have no idea how to do that. Can you help?
Install, accept the rooted user request access and then you will see you CPU frequency settings.. The lower number 100 Mhz, just slide the slider bar a bit and it will move to 200 Mhz.
Thats it.. No big deal... This could be your problem, maybe not but I know many users have trouble running at the 100 Mhz because their phone doesn't want to wake up from that low of a frequency or simply just freaks out sitting ideal during use at that lower frequency.
make sure you have the right version of CWM. This same problem happened to me when I had the wrong version.
~SS
I am currently on 1.1.0, been on it for about 2 months now. It's the first time I've ever flashed a phone, and I'm curious about what's involved in upgrading to 1.1.1. Do I have to go through the entire process of wiping the phone and reflashing everything, or is there a simple upgrade? Thanks
ZiggSeVO, Thank you so much for the answer. I successfully upgraded to 1.1.1 last night without a hitch. I have one last question that I've been searching everywhere for but can't find the answer to.
I've seen a few people mention that they are on this ROM and running the EE03 modem, which I hear has much better reception, I'd like to try it out. I didn't know you could flash JUST a modem, and if so, how is it done? Thanks
Click the link in my signature.. I have a video showing you how to![]()
I may be missing something obvious- when I try to use Voltage control on this ROM and kernel, I dont get the pull up tab to specifty what speeds I want. I only get the scrolling options to undervoltage.
Is this how the kernel is set up? I ended up using SetCPU instead for this Kernel/Rom.
You should be able to use VC? First I've heard it not working on this kernel...
I do know that ACS is working on a better simpler way to control both clocking and volting
Phone is in my truck right now but I'll check Voltage Control when I get it out of there
Edit: ok so i have all the options to change my voltages at all the freq up to 1.3? so not sure exactly what your meaning?
